Thread: Help with an ancient digital timer
    Oct 2011
    Southeast
    Default Help with an ancient digital timer
    Yesterday I was going to shut off the filter with my timer. I always shut it off with the manual override versus the breaker box. Well yesterday the manual override did not work, it would not shut off in any mode, (program, manual, etc.). I changed the time to go off at 5PM and when I came home at 10 it was still on. It states that the display will blink when you've done the last step however mine did not blink at all. I'm hoping it's just a matter of new battery, if not....any ideas???? I called the company but this is so old that no one had any info on it. If anyone knows about this kind, it's a BRK Electronics 24 Hour Electronic Time Switch. Model # TS212R
    16X32 Inground 23,000 gal vinyl lined Hayward S200 High Rate Sand Filter Hayward Super Pump 1HP 20GPM 8.25% Bleach for chlorinating.
  1. Autopilot Digital 220 - low amps--cell?
    By annm27707 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-07-2013, 01:43 AM
  2. Digital pump timer recommendations
    By 4pkross in forum Pool Equipment & Operations
    Last Post: 07-15-2011, 09:22 AM
  3. cast iron vs. plastic headers in heater, digital vs. non-digital
    By vinouspleasure in forum Pool Equipment & Operations
    Last Post: 05-08-2011, 06:49 PM
  4. Looking into SWG! Aquatrol or Autopilot Digital
    By fuelman in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 09-14-2007, 11:28 PM
  5. digital PH testers
    By slowtan in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-13-2007, 01:31 PM
