Thread: new user--trying to fight the algae!
    May 2013
    Alabama
    Default new user--trying to fight the algae!
    Hello all, and let me say thank you so much for everything that I have learned already. I just wish I had found y'all two weeks ago!! I am a new home/pool owner and trying to get our pool open for the summer. We unfortunately let our pool go uncovered and untended during the winter and so we started with a swamp. No frogs thankfully! lol but we were probably close. I went to the pool store and have dropped at least $250.00 into our pool and we still have algae and milky water. I have been vacuuming every day at least once (some days two or even three times) since Thursday. We have a rectangular pool (with the corners cut off at angles) the measurements are approx 18x33. If the online calculator is correct we have about 25,000 gallons. I have a Taylor kit on order (will arrive next week) and I am making due with a basic OTO kit right now. I am going to try the diluted chlorine test this evening after the sun is off the pool. here is a list of everything that has gone into our pool in the last 10 days:
    Swamp to swim 3 boxes (appears to be cal hypo 52%) approx 18lbs total (almost 6lbs/box)
    25lbs of ALK up
    20lbs of pH up (sodium carbonate 100%)
    32oz Algimycin2000 (polyquat 20%)
    6lbs SuperSonic (shock treatment) (cal hypo 73%)
    approx 1/2 box borax (since reading on here)
    5 gal basic unscented bleach (since reading on here)
    My current levels
    chlorine around 4.0 (but going to do the diluted test this evening)
    pH 7.4
    alk 290
    I am not sure if I need to try to bring the alk down or just leave it for now and try to focus on the algae first. And if I do need to get the alk down ----how? I have put so much in the pool to try to raise the pH--should I lower it to lower the alk then raise the pH with Borax so that it won't affect the alk? or just leave it alone for now? Also if I need to do something different to fight the algae please let me know.
    Thanks!!
    Michelle
    Default Re: new user--trying to fight the algae!
    1. Do not worry about alkalinity right now.
    2. Run your pump / filter 24/7
    3. Keep your chlorine high
    4. Do not purchase any more 'blended' chlorine -- chlorine % for dichlor should be 55% or higher; trichlor 89% or higher; cal hypo 65%.
    5. Remove all the physical debris -- brush, vacuum, filter.
    6. Once the debris is gone, you should have the K2006 (hopefully) and can focus on finishing the job.
    May 2013
    Alabama
    I forgot to include that I have an inground pool with a vinyl liner, and a Hayward pump S-220T model
    May 2013
    Alabama
    Thanks Ben!! so it sounds like I am going in the right direction then. yay!! How much bleach does it take to raise the Chlorine level typically? I haven't found that info on here yet. I haven't bought anymore blended products since finding the site--the others were from the pool store, but I know better now.
    1 gallon of 6% bleach will add approximately 2 ppm of chlorine to your pool.
    May 2013
    Alabama
    Thanks!!!
    IG Vinyl liner, 25,000 gal rectangle. Hayward chlorine pump.
    May 2013
    Alabama
    My Taylor kit came in today!! Way ahead of the promised date of June 4th!! Yay! so after reading the manual and feeling a bit like a mad scientist, I have readings:
    FC 25
    CC 2
    pH 7.4
    Alk 600 (and sample was still yellow--I gave up after 60 drops and no red)
    CH 210
    Cya 130-ish (the test read over the 100 mark-well technically below the 100 mark)
    I am still keeping the algae swept up into the water and running the pump 24/7. Any advice would be greatly appreciated. Thanks!!
  1. Anxious New Member fight algae
    By kcoussou in forum Dealing with Algae & Slime
    Last Post: 06-27-2012, 10:42 AM
  2. new user, old pool, trouble with algae
    By ksukris in forum Dealing with Algae & Slime
    Last Post: 05-25-2012, 02:55 PM
  3. Adding bleach to fight algae without knowing the exact chlorine and stabilizer levels
    By galaxyraider in forum Pool Chemicals & Pool Water Problems
    Last Post: 09-19-2011, 07:20 PM
  4. Another Algae Fight - Am I doing this right?
    By Airren in forum Dealing with Algae & Slime
    Last Post: 07-26-2011, 10:25 PM
  5. borax over the winter to fight algae
    By fuelman in forum Dealing with Algae & Slime
    Last Post: 11-19-2007, 08:05 PM
