Thread: Musty or vinyl odor to pool water
    May 2013
    Ohio
    Default Musty or vinyl odor to pool water
    We have a new 14x28 vinyl liner in ground pool with chlorine sanitizer, heat pump, and automatic pool cover. Water is well balanced and clear. There is no obvious mold or algae. Water has persistent odor best described as a vinyl or musty smell. Any ideas on cause and solution?
    Default Re: Musty or vinyl odor to pool water
    Membership updated.
    New liners off-gas plasticizer, which may be the odor you smell. A couple of weeks of chlorine and sun should handle it, if that's the problem.
    Occasionally, city water may have odors, especially after heavy rains. Some of the compounds which produce the odors are chlorine resistant. But again, a couple of weeks of full sun and full chlorine will usually resolve it.
  1. Pool storage and odor
    By Lynn62 in forum --cleanup--
    Last Post: 09-30-2012, 03:23 PM
  2. Cut above water line in AG vinyl liner pool
    By cjblanton07 in forum Above-Ground Pool Construction & Repair
    Last Post: 07-20-2012, 08:30 AM
  3. Odor in Pool after Algae Treatment
    By TerGerKub in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-01-2011, 12:02 PM
  4. lowering water in vinyl liner pool
    By maxhiller in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-04-2006, 12:31 AM
  5. Musty Smell...
    By Elias in forum Pool Chemicals & Pool Water Problems
    Last Post: 05-29-2006, 09:29 AM
