Thread: Pool Walls Buckling In
    May 2013
    Usa
    Default Pool Walls Buckling In
    We just installed a new beaded liner to our 24' above ground pool with 48" wall. Everything was going great but when I went to check on it, I found that the pool wall is begining to buckle inward in a few places. It looks like the weight of the water is pulling down on the liner, causing it to buckle in. The liner appears to still be centered (there are no creases or wrinkles, and no excess lining anywhere) the buckling seemed to start towards the evening when the weather became cooler. Is this buckling of the walls due to the liner contracting from the cold tenperatures, and if so, will it stretch back out when heated by the sun? Will simply continuing to fill the pool be enough to lift the pools walls back up to where they belong? Please help...I have no idea what to do!!!
    Default Re: Pool Walls Buckling In
    I can tell you that tension caused by a cold liner will be greatly reduced on a warm day. But, I have no idea if that is the cause of your problem.
    Membership updated; post moved to correct section.
  1. Pool walls?
    By Willdog in forum --cleanup--
    Last Post: 06-03-2013, 12:56 AM
  2. Pool wall buckling
    By sharkfood in forum Above-Ground Pool Construction & Repair
    Last Post: 06-10-2012, 11:27 PM
  3. NEWBIE - Pool walls buckling while filling
    By wcalasan in forum Above-Ground Pool Construction & Repair
    Last Post: 05-29-2012, 01:43 PM
  4. Esther Williams AGP, wall buckling, cove?
    By jimmymustang06 in forum Above-Ground Pool Construction & Repair
    Last Post: 07-24-2011, 08:55 PM
  5. help --liner rip in winter; pool losing water and walls buckling
    By blondie_30 in forum Above-Ground Pool Construction & Repair
    Last Post: 01-22-2009, 12:36 AM
