Results 1 to 8 of 8
Thread: Cracked Hayward Superpump housing
    May 2013
    Northeastern US
    Default Re: Cracked Hayward Superpump housing
    Quote Originally Posted by NormP View Post
    The drain plug on my Hayward pump was over tightened and cracked the housing through the treads approx. 1 cm.
    The pump is approx. 2-3 yrs old. Is there a product available to repair/re-bond the crack?
    Thx
    Yes There is a great product for something like that. It is call Marine Tex. It comes in gray or white. I would make sure the site is very dry before applying it, and apply it inside the housing and outside the housing. It is very strong and impervious to water. You can buy it from any marine supply place, cheapest is probably www.defender.com. Or check ebay
    May 2013
    Northeastern US
    Quote Originally Posted by hotajax View Post
    Forgot something: Use Teflon tape when re-installing the drain plug. Also it won't look pretty, but spread the Marine Tex out at least half an inch from each side of the crack. Do you want it pretty or functional? Last time I bought pump housing it was going for over $200 list.
    May 2013
    Canada
    I applied Marine Tex to the outside of the pump and I used Teflon tape and plumbing pipe joint compound on the threads before I applied the drain plug and far no leaks. Marine Tex worked well! Thanks again for the suggestion.
    Cheers,
    NormP
    Great! One more tool in our tool kit of how to fix things!
    May 2013
    Canada
    Thanks for the info.
    membership updated; thread moved to appropriate section.
    . . . If you try to repair your housing, I'd be interested to here what the results are.
    May 2013
    Canada
    I going to try using Marine Tex tis weekend, I will let you know how it works.
    NormP
  1. Hayward Perflex EC-75 - cracked flextubes?
    By bobjersey in forum Pool Equipment & Operations
    Last Post: 10-28-2014, 06:49 PM
  2. Crack in Hayward Super pump housing wth pics
    Last Post: 03-04-2012, 12:03 AM
  3. Hayward SuperPump-Can't Loosen Impeller
    By Spurgeon in forum Pool Equipment & Operations
    Last Post: 05-12-2010, 12:57 PM
  4. skimmer housing cracked.
    By packerfan in forum In-Ground Pool Construction and Repair
    Last Post: 05-21-2009, 08:35 AM
  5. Hayward 4800 D.E. Filter and Superpump Installation...
    By leejp in forum Pool Equipment & Operations
    Last Post: 05-18-2007, 03:01 PM
