Thread: Convert FROM Pristine Blue to chlorine
    May 2013
    Southeast MA
    Default Convert FROM Pristine Blue to chlorine
    I inherited a 24 ft AG round pool that hase used Pristine Blue since it was installed in 2007.
    What do I need to do to get started? I just got a new sand filter for the season to replace old filter with a hole in it.
    Thanks in advance!
    May 2013
    Southeast MA
    Default Re: Convert FROM Pristine Blue to chlorine
    Too costly to refill the pool. Opened it up over weekend and have the following test numbers:
    FC=0
    TC=0
    PH=6.0
    Alk=30
    Hard=70
    CYA=0
    What is first step in process? HELP
    BigDave's Avatar
    I don't know anything about Pristine Blue - sorry. But I can say that a pH of 6 will very likely be damaging to the pool. If this were a chlorine pool, I'd recommend raising the pH with Washing Soda (will also raise Alk) or Borax.
    what is the copper level. Knowing that will give us info on how to proceed. If it is high it is very likely that the liner will get stained if you don't drain and refill at least partially. There are ways to help remove the copper but they are no inexpensive.
    May 2013
    Southeast MA
    I got water tested other day:
    Got the ecopper level tested last night! Here are the latest numbers:
    FC= .31
    TC= .31
    PH= 7.1
    Alk= 33
    Hardness= 12
    CYA=4
    Copper = 1.0
    I added a 32 oz bottle of Magic Jack Blue stuff to water last night.
    Added 4 lbs of CYA to bring up!
    What is my next step?
  1. Want to switch from Pristine Blue to Chlorine
    By SandSpringsGrandma in forum --cleanup--
    Last Post: 06-19-2013, 11:12 AM
  2. Pristine Blue stained my pool and I want to switch to BBB /Chlorine
    By efxs25 in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 06-02-2013, 06:41 PM
  3. Pristine blue to chlorine
    By 1969scrapper in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 07-29-2012, 05:45 PM
  4. Want to convert from Pristine Blue to Chlorine
    By Michelle W in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 05-07-2012, 09:02 PM
  5. Pristine Blue to Chlorine?
    By Kreebog in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 05-19-2006, 06:53 PM
