Thread: High AK, Is it ok to start with the bleach.
    May 2012
    Iowa
    Default High AK, Is it ok to start with the bleach.
    Brought my water level up. Let it pump run for a day. Tested Ak (first step I think) And it came out pretty high 120 ppm. Do I need to get it down to the 10 ppm range before I begin adding Chlorine?? (pool is a dark green)
    Also I may have jumped the gun a little starting it up. Calling for 29 deg F over the weekend. I figure as long as I keep the water moving in the cold my pump should be OK as long as its not an extended temp drop. Will this temp drop effect what I am doing with start up??
    Thanks in advance. After all the great advice last year. Consider me a lifelong member of this site.
    Bryan
    24 round 12.9K* gal AG vinyl pool; liquide chlorine; sand filter; 2 1 speed pump; 8 hrs; ; the recommended Taylor kit; utility water; summer: solar; winter: mesh; android phone; PF:9.3
    May 2012
    Iowa
    Default Re: High AK, Is it ok to start with the bleach.
    haha thanks I tried to edit with the proper abbreviation but I guess my post still need approved. Been moving forward light aqua green now. Will the cold weather effect it in any way?
  1. Fresh fill with city water - start with bleach or dichlor?
    By Mm_putnam in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-27-2013, 02:22 PM
  2. Sand filter changed @ start of season ? HIGH PRESSURE @24 PSI FROM START
    By timmygreene in forum Pool Equipment & Operations
    Last Post: 05-21-2010, 07:48 AM
  3. Clorox High Efficiency bleach???
    By mariner09 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-05-2008, 06:22 PM
  4. Pump sputtering bad on start up (high speed)
    By mjs31 in forum Pool Equipment & Operations
    Last Post: 10-15-2007, 01:39 PM
  5. Filling and when to start adding bleach
    By NWMNMom in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-28-2006, 10:29 AM
