Results 1 to 8 of 8
Thread: Calcium Hardness in in vinyl pools?
    Default Re: Calcium Hardness in in vinyl pools?
    Pool manuals (Intex, as you point out) list standard water chemistry parameters without regard to the material of the pool surface. That is wrong, but if you decide to follow manufacturer's recommendations you'll just spend more money, but not do any harm. The saturation of pool water with calcium carbonate is to protect plaster surfaces (and grout in tile), but is not needed for vinyl nor fiberglass though having some calcium hardness for fiberglass can help to prevent cobalt staining.
    Chem_geek is more detailed than me but I still don't know if it has any effect on SWCGs.
    As far as I know, calcium is not needed for SWCGs and in fact a higher calcium level (or more technically a higher calcite saturation index) can lead to more calcium carbonate scaling in the SWCG. One generally targets a slightly negative saturation index in a plaster SWCG pool, but in a vinyl pool it can be more negative since there are no plaster surfaces to protect.
    I would go with chem geek's chemistry any day unless one of our specialists on SWCG, like PoolSean ventures a different opinion.
    Jun 2012
    GA
    Now I remember last year. I was maintaining the recommended calcium level in my Intex/SWG pool and I had a terrible time with calcium carbonate packing up the electrolysis cell. Had to soak it in HCl plus some scrapping with a thin piece of plastic to get the cell cleaned out three times. I wonder if those calcium carbonate deposits could short out the cell or at least reduce it's ability to create chlorine from chloride.
    Richard
    We've seen NO data indicating that you need to ADD calcium, for the benefit of an SWCG. But, as you've seen, even 'normal' levels of calcium increase SWCG maintenance.
  1. Calcium Hardness
    By kinetique in forum Dealing with Alkalinity and Calcium
    Last Post: 11-15-2012, 07:12 PM
  2. Calcium Hardness (CH) for Vinyl Pool Liners
    By chem geek in forum The China Shop
    Last Post: 06-28-2012, 09:46 AM
  3. Calcium & Vinyl Pools
    By Cav2473 in forum Dealing with Alkalinity and Calcium
    Last Post: 06-09-2011, 11:17 PM
  4. Low calcium hardness in vinyl pool ok?
    By rockg in forum Dealing with Alkalinity and Calcium
    Last Post: 06-07-2010, 06:21 PM
  5. Calcium hardness and fiberglass pools
    By aguaguy in forum Dealing with Alkalinity and Calcium
    Last Post: 05-13-2008, 04:17 AM
