Results 1 to 10 of 10
Thread: Pool hum
    Oct 2012
    TX
    Default Re: Pool hum
    Yup, capacitor prob. you can unplug the capacitor in the back cover of the motor. Test it with a multimeter if you like. $12 part. Make sure to get the correct replacement or itll blow up!
    Honesdale PA
    I assume the 'switch' you refer to is the starter switch and you are rotating the rotor. Sounds like you jiggle the switch in the process and it runs. Capacitors usually fail and do not fix themselves, that is, become inermittent. The centrifugal starter switch could have crummy contacts so if you can get in there with a thin, flat file that is best. Next best is to use some 600 grit paper, fold it a couple times to give it some stiffness and dress the contacts. Just a few swipes should do it.
