Results 1 to 10 of 28
Thread: The Algae Wars Continue - - -
    BigDave's Avatar
    Default Re: The Algae Wars Continue - - -
    You've got it!
    1) pH over 8 needs to be fixed.
    2) Chlorine kills algae.
    2) ...
    2) ...
    2) algae dead
    3) adjust calcium to protect concrete
    Sep 2012
    Middle Tennessee
    Exclamation Re: The Algae Wars Continue - - -
    Last night I added 5.68 gal. of bleach and this morning I had the following results:
    pH looks to be a solid 8, FC 11, CC 2
    The water is cloudy and still has the 'algae' look to it. I expected almost 6 gals of bleach to give me more than a 2 point bump in FC so I it looks as though the war continues.
    Something is using up the chlorine and as cool as it's gotten around here no one is swimming. I'll go with the algae losing the battle.
    I'll test again in the morning and hit 'em again.
    This is a 'take no prisoners' kind of war -
    Thanks -
    20x40 rectangle 36K* gal IG painted concrete pool; Chlorinator; Tagelus sand filter; Century Centurion 1 speed pump; 8 hrs; solar heat, Solar Heater home made; Taylor K-2006; utility water; summer: none; winter: mesh; android phone; PF:4.4
    Quote Originally Posted by tenndoc View Post
    You've got the right attitude At least with the water temps getting cooler, it should slow your chlorine consumption a little more. Keep at it!
    Sep 2012
    Middle Tennessee
    Question Re: The Algae Wars Continue - - -
    Am I not using enough bleach? The most I've been able to raise the FC is to 11. It drops to 8 so I know I'm still killing algae. I add 5.84 with a goal of 19 FC starting at 11 and I still have cloudy water!
    No one has used the pool in 3 to 4 wks. so I'm considering raising the CH (it's 110 now) closing the pool and opening it up early next year.
    Thoughts or suggestions are appreciated -
    Thanks -
    doc
    tenndoc, what is your current CYA level? A FC of 11 is not high enough for algae killing--it will need to go higher, but earlier in this thread I saw that you had added some CYA and your current level will tell you how much chlorine you need. Also keep in mind that the algae, live and dead, in the water is what makes it cloudy. You need to have your filter running 24/7 and backwash it when the pressure rises 6-8 psi over the "clean" pressure. Do you notice a rise in your pressure gauge?
    Sep 2012
    Middle Tennessee
    Thanks aylad,
    I'm at work now so it'll be tomorrow before I can post those numbers.
    My frustration comes from adding almost 6 gal of bleach and not getting a FC level near 20. I've got some dichlor (sp) from Wal-Mart but its got .63% copper so I haven't used it.
    According to poolcalclator.com 6 gal of bleach should have given me a FC level of 19 on a 36,000 gal pool. How much is too much bleach to add at once? I would like to get this resolved so I can get it covered before it gets full of leaves.
    Thanks for your help, I'm just getting frustrated with these results. I'm probably not hitting it hard enough to do the job . Early this summer the pool place tried to tell us we had some kind of chlorine eating algae. We've battled this problem all summer and.I'm willing to use this method I really need to see some results though.
    Sorry, nothing like a rambling post to really confuse things.
    LOL, all algae eats chlorine I suspect you're just not getting the chlorine levels high enough and not sustaining them. Post up your CYA level when you get a chance and we'll see.
  1. Avoiding Algae / Removing Algae
    By PoolDoc in forum Dealing with Algae & Slime
    Last Post: 07-24-2011, 09:40 PM
  2. Cloudy water...then very small amount of algae...then algae bloom
    By Allan in forum Dealing with Algae & Slime
    Last Post: 07-12-2011, 09:49 PM
  3. Why would ph continue to go up?
    By Ramblinwreck76 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-30-2011, 05:00 PM
  4. Green algae? Mustard algae?
    Last Post: 07-15-2007, 08:32 PM
  5. Why does my Ph continue to soar
    By Madty in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-04-2006, 12:00 PM
