Quote Originally Posted by DrBAF View Post
Reading a number of forums it seems like resealing is a peace of cake. Just make sure everything is squeaky clean, install a new gasket and tighten it up. Well, I have done that now four times. Each time water leaks in behind the lens. My CFLs turn on perfectly but I shut them off when I see water behind the lens. This has been incredibly frustrating. I have tried using the old gasket, a new gasket and the new gasket sealed with silicone seal. On that last attempt, I let the silicone seal dry for several weeks before reinstalling the assembly but it also leaked. It has now been a year and I have no new ideas. The pool light just sits on the deck starring at me, mocking me.
I don't have a good solution for you but I just wanted to share that I have felt your pain! I spent MONTHS fighting with a light that kept leaking. Posted here about it several times, talked to local pool guys, pool stores etc. I never got it to be leak free and ended up replacing the whole light with an LED unit. Everything I have read indicates you are supposed to replace that seal with a brand new one every time you open the light. I'm not sure if I believe it given the massive amount of misinformation pool industry companies engage in to sell more products.
I had a pool guy come out to put the new light in and he said he thought my problem (with the old one) was that the glass lens didn't match the light. He may have been right, but we never were able to identify even the brand of the light I had - so I don't see how he could have been sure.
Good luck, and sorry I don't have a solution for you either.
