Results 1 to 10 of 22
Thread: Pool a disaster after vacation
    Aug 2012
    Virginia
    Default Re: Pool a disaster after vacation
    I tried the flok. First tried adding it as a filter aid since the filter didn't seem to be doing anything (pressure never goes up). Then, when that didn't work, got my chlorine up high and used the flok and waited two days, got it to settle to the bottom. But, when I vacuumed, all it did was stir everything up again. I waited overnight and it settled again and I vacuumed again. Once again, evrything got stirred up when I vacuum. Didn't want to leave the filter off any longer or the algae would retun. Very slight improvement. I can now see the bottom step.... Any other suggestion? Pool is a beautiful blue color, but opaque.
    Also, I tried updating my profile with pool info, but can't save it....any thoughts.
    I'll order a test kit today.
    20x40 grecian 27K gal IG vinyl pool; skimmer tabs; eclipse sand filter; hayward ultraflow, 1.5 hp 1 speed pump; 10 - 24 hrs; ; strips - aqua-chem 6-way; pool store testing; orig truck, topped off w/ well; summer: ; winter: mesh; laptop; PF:4.4
    mbar's Avatar
    Ashland, PA
    Did you vacuum to waste? You have to vacuum really slow to waste, then leave the filter off while you refil. Let it settle again and continue till clear
    Northeast PA
    Aug 2012
    Virginia
    Yes, vacuumed to waste. I thought I was going very slowly.....just stirred it up with the slightest movement. My vac has bristles all around the edge, could that be the problem? If I try again do I need to add more floc? It's been filtering for several days now since I tried the vacuuming. Pool filter pressure doesn't go up at all. Water still blue/white and opaque.
    How do you make a skimmer sock? I have lots of old stockings
    Eclipse sand filter? Is that the little round one? There's a fair chance you've lost quite a bit of your sand. If it's a side mount filter, it shouldn't be too hard to open the filter at the top, and check. If you are missing a lot of sand, the algae particles will go right on through the filter (and a skimmer sock won't help either!).
    If you want to test your filter BEFORE opening, it, you can add some DE powder -- a couple of quarts -- via the skimmer. If the DE shoots back into the pool, your filter needs work!
    Aug 2012
    Virginia
    hmmmm...never thought of that. How would it lose sand? But, we've had it 10 years and never added. Foxx pool manual said it would never need more sand. It is the little round one. I'll try the DE test you suggest - I get that at the pool store? I put on a stocking skimmer sock earlier today....figured it wouldn't hurt.
    Aug 2012
    Virginia
    Ok, just looking at your Pool Solutions FAQ about Alkalinity and read:
    "My calcium hardness (CH) level is also too low. Can I raise my ALK or TA level and raise my CH level at the same time? Not unless you want to have a pool that looks like it's filled with milk! When you try to add baking soda and calcium chloride (AKA calcium hardness increaser), you almost always end up with a zone where both the ALK and the CH are too HIGH, at least temporarily. And during that brief period the ALK and CH combine to firm fine particles of calcium carbonate (limestone) that cloud your pool."
    As I said before, my pool dealer said to wait 6-8 hrs between the 20 lb of each additions (and each of those increments) but I was overzealous and didn't wait more than an hour or two between additions. Based on what I just read, I'm wondering if I have a "limestone cloud". If so, does that change any of your advice?
    Aug 2012
    Virginia
    Still waiting on the test kit from Amazon. I haven't been able to get to the store for DE, but had a question on that....if the DE does blow through showing I need to replace sand, what kind of additional problems will the blown through DE cause?
    Thanks a bunch.
    Chantel
    DE blowing through may mean your filter is damaged, not just that you need to change your sand. If it does blow through, let it settle on the pool floor and then vacuum to waste to get it out of the pool.
  1. Vacation pool
    By donfranko in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 04-07-2012, 05:21 PM
  2. Well water disaster
    By zipsman03 in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 06-08-2011, 03:13 PM
  3. Now WHAT?!!! Pool Disaster
    By Trimom in forum Above-Ground Pool Construction & Repair
    Last Post: 05-04-2007, 11:46 AM
  4. Liner disaster
    By joing in forum Above-Ground Pool Construction & Repair
    Last Post: 07-22-2006, 04:54 PM
  5. Conversion - Baquacil to Chlorine - Disaster!!!!
    By jmaj43 in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 07-12-2006, 01:19 AM
