If no air is going through your pump, the only way air could get in your lines is if you have a spa type venturi somewhere: any leaks downstream of the pump will let water OUT, instead of letting air IN! (There are a few uncommon exceptions, involving pools at different levels from the pump.)
However, you may not have noticed a small amount of air . . . and if you have an OFFLINE chlorinator, those are notorious for creating small suction leaks.
