membership upgraded; Pool Chart data processed to signature.
Note the very significant difference between the gallons figure calculated from your dimensions, and the one you supplied directly.
PoolDoc / Ben
I can confirm it is not the bulb....I had ordered a replacement bulb and was in process of replacing it. It is a 120V light. I have 120V as the junction box but nothing at the light. Internal to the light there is a "metal" cap that appears that it covers a "circuit" that would trip the breaker if water was in the light cavity. The cap easily (too easily) popped off and i found the "circuit" is rusted beyond repair. (Obviously some water had gotten it at one time - I should note that the light cavity was dry when I went to replace the bulb). Note - the retaining screw is slotted....I would like to replace the light housing. But since the Startlight series is old, I cannot find a replacement part. I am looking for advice on what replacement assembly will fit in the existing niche.
18x36 rectangle 19.4* gal IG vinyl pool; skimmer tabs; Pacfab DE filter; 1 speed pump; 8 hrs; utility water; winter: vinyl / water bags; android phone; PF:6.2
bump - any thoughts on what will fit as a replacement light assy?
I'm not 100% sure but any light should fit the existing niche, even between brands, the niches are fairly uniform and will accept a new light housing.
Have you talked with Hayward?
If you need help removing the old housing & cord and installing the new one - or, if you actually need the niche replaced - get back to us.
