Results 1 to 10 of 17
Thread: Pump Ran Dry Now Motor Won't Start
Threaded View
  1. #9
    Aug 2012
    Jersey Shore
    Default Re: Pump Ran Dry Now Motor Won't Start
    True enough!
    Although I can't say that I ever noticed any leaking around the pump at all. The majority of the corrosion was behind the motor mounting plate where it attaches to the front of the motor. Also under the front of the motor where the air cooling slots are located. But none of that was visible until taking everything apart.
    I did notice some bearing noise in the motor this season and had planned to pull it (the motor) to have the bearings replaced after closing the pool in the fall. The bearing noise was noticeable but not horrible and I'm sure it would have made it to the end of the season (mid-September for me) had the seal failure not occurred. I may still rebuild the old motor and either keep it as an emergency back-up or see if I can sell it on E-bay. I can tell you that going forward I will be much more attentive to the sound of the pump motor and I'll be on the lookout for any signs of leaks or corrosion.
    In the meantime, thanks for the help and the words of encouragement. It's nice to know I'm not alone out here!
    18x36 free-form 24K gal IG vinyl pool; SWCG; Hayward Pro Series HDS244T sand filter; 2 HP Single Speed Hayward Super Pump SP2615X20.
  1. Recommendations For Replacement Pump Or Pump Motor (1.5" Piping, High Head)
    By ChuckDavis in forum Pool Equipment & Operations
    Last Post: 05-25-2013, 04:56 PM
  2. Replace motor or pump and motor?
    By myLABSpool in forum Pool Equipment & Operations
    Last Post: 05-25-2013, 02:13 PM
  3. One motor primes pump another motor wont????
    By jmurch in forum --cleanup--
    Last Post: 12-17-2012, 11:47 AM
  4. Replace motor or motor& pump?
    By jtcaputo in forum Pool Equipment & Operations
    Last Post: 09-08-2012, 08:27 PM
