Results 1 to 10 of 14
Thread: copper tubing?
    Jul 2012
    Mexico, Missouri
    Default copper tubing?
    I don't know what the commercial heaters use in their heat exchangers, but I suspect it would be stainless steel.
    Would there be a problem with using copper pipe in a home built solid fuel heater? If there are serious cons to this, I do have another method in mind, it just involves a lot more work, along with lower efficiency.
    Would copper tubing require keeping a really close watch on pH? Would I be introducing copper ions into the pool? I've seen via the internet, many examples of people using copper in home built heaters, but with my lack of knowledge in this area, are they asking for green, copper laden pools?
    Thanks for any info you can provide!
    15' round 4.8K gal Intex AG pool; Intex 633 pump with twin canisters (2500 gph main filtering); Unicel 5315 filter cartridges; Intex 637 pump w/o filter (1000 gph heater circulation); 4hrs; K-2006; utility water; PF:24
    Jul 2012
    Mexico, Missouri
    Default Re: copper tubing?
    I guess no one has any thoughts on this?
    You can use copper if you keep the pH between 7 and 8, and don't use salt.
    The heat exchangers in commercial pool heaters are copper, just like they are in residential units. However, salt-compatible residential units have cupro-nickel exchangers -- stainless steel is a poor conductor and is not used.
    NOTE: this is NOT a recommendation that you actually DO any of this. Building a heater is potentially life-threatening! It's surprisingly easy to build a water bomb -- when home water heaters explode they often level the house and kill everyone inside!
    Here are 2 videos you should watch, before you go further:
    50 Gallon water heater explosion
    Mythbusters Water Heater Explosion
    Jul 2012
    Mexico, Missouri
    Yes is would be dangerous if I used a closed container, without a temperature/pressure relief valve. Obviously, in both the videos, those key pieces of SAFETY equipment had been removed and the hole plugged.
    If you have ever seen a properly equipped tank go into thermal runaway, the T/P valve lets loose well before an explosion can happen.
    In this case, YES, I would plumb in a T/P valve. In addition, NO fire would be lit without water flowing through the heat exchanger, and would continue to run well after the fire was out. Under no circumstances would this be left unattended. There would be no pressure vessel (tank) involved in this build, if I do decide to go through with it.
    As I said, building a heater is potentially life threatening. You seem familiar with the safety devices typically used on water heating systems, so I presume you can experiment safely. But I didn't know that when I posted. There have been 3 or 4 prior posters this year with some other DIY pool heating system ideas and not one of them had a clue about safety.
    When I post as I did above, I'm not only writing for you -- since you hadn't mentioned T&P valves, etc -- but also for all the lurkers who will Google "DIY pool heater", and end up here.
    Jul 2012
    Mexico, Missouri
    I agree with your reasoning behind the reply, and I appreciate the reminder. I like the fact you care enough to post that kind of safety warning.
    Thanks for understanding!
    Jul 2012
    Mexico, Missouri
    Well, I did it.
    Took an old bbq grill for the housing/firebox, and bought 50' of 3/4" copper pipe along with a bunch of tees and els etc. Even with the fairly small firebox, I'm able to keep 80* water with overnight temps in the high 50s to low 60s, burning junk pallet wood.
    I do need to make a few improvements to it, mostly to the flue gas path to bring more of the hot gasses in contact with the copper for longer time. I'm also going to have to enlarge the firebox a bit so I'm not having to add wood so often.
    Took a swim this afternoon, 65* air temp, 82* water. felt good, as long as I was in the water, but getting out was problematic.....I got cold real quick!
    Jul 2012
    Mexico, Missouri
    I goofed. Cost me 2/3 of the water in the pool.
    Heater exterior was cool enough to hold my hand on. so I shut off the pump last night. Got up this morning to a muddy mess. One PVC joint failed, and broke free. I assume from residual heat in the firebox.
    However, the up side to this is I was able to make the improvements to the heater.
    Incoming fill water is measured 63*, yet the pool is holding at 72*, while filling. Current air temp 64*, high today was 68*.
    I guess that means the changes to the heater are successful. Looks like I'll be able to get the water back to swimming temperature by tomorrow afternoon. Shooting for 80*+. Anything over that is just gravy......
    Jul 2012
    Mexico, Missouri
    According to the typical internet meme, pics or it didn't happen, right?
    With that said, here is what is happening:
    Overall view of the system --
    Yes, it looks hillbilly. That is what happens when you use what you have on hand. No filter in the canister, to keep the flow rate fairly decent.
    Nice bed of coals --
    This is what a pile of used, broken pallets are good for.
    Detail of the suction/return lines --
    And of course, I can't forget the thermometer --
    According to http://www.wunderground.com/cgi-bin/...:65265.1.99999 current air temp is 68*.
    I must have done something right, this time!
  1. New member- chemical tubing question
    By Penypool in forum Commercial Pool Users, Managers & Workers
    Last Post: 06-13-2013, 02:05 PM
  2. Pool pump tubing - PEX?
    By ArmyChief in forum In-Ground Pool Construction and Repair
    Last Post: 07-29-2012, 08:19 AM
  3. CL2 migration through poly tubing
    By pmeloy in forum The China Shop
    Last Post: 11-26-2011, 01:49 PM
  4. Copper??? Nooooo!
    By shadowman in forum Dealing with Algae & Slime
    Last Post: 05-30-2009, 01:57 AM
