Help
Remember Me?
Forum
FAQ
Calendar
Forum Actions
Mark Forums Read
Quick Links
View Forum Leaders
What's New?
Advanced Search
Forum
Odds-n-Ends (P)
The China Shop
Alum, borax, etc.
FAQ
register
Results 1 to 10 of 21
Thread:
Alum, borax, etc.
Thread Tools
Show Printable Version
Email this Page…
Subscribe to this Thread…
Display
Switch to Linear Mode
Switch to Hybrid Mode
Threaded Mode
Threaded View
08-07-2012
09:59 PM
#9
Spensar
View Profile
View Forum Posts
Subscriber
Widget Weaver
Ontario.
Re: Adding Borax to Make your Pool Resistant to Algae
Interesting stuff, thanks.
Quick Navigation
The China Shop
Top
Site Areas
Settings
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
Forums
Ben's Corner
Forum Q & A
-- Subscriber Posts --
Dealing with Algae & Slime
DPD-FAS based testing
Pool Equipment & Operations
Pool Electronics
Odds-n-Ends (P)
Photo Gallery
Clearance
--cleanup--
The China Shop
General Interest
Practice Forum
PoolSolution Archive
The Hall of Shame
I'm still being moderated. What to do?
Answering Questions at the PoolForum
Cloudy Water After Alum
By At wits end in forum Pool Chemicals & Pool Water Problems
19
Last Post:
04-10-2012,
02:08 PM
Too much borax, now ph +8.0
By joecus in forum Pool Chemicals & Pool Water Problems
6
Last Post:
05-25-2011,
11:30 PM
Borax
By fcfrey in forum Testing and Adjusting Pool Water Chemistry
11
Last Post:
07-01-2006,
01:25 AM
Should I use Alum to get rid of silt and mud
By Amir in forum Using Chlorine and Chlorinating Chemicals
1
Last Post:
06-28-2006,
01:39 PM
Alum - where to buy?
By LukeNorris in forum Pool Chemicals & Pool Water Problems
4
Last Post:
06-16-2006,
06:57 AM
Digg
del.icio.us
StumbleUpon
Google
You
may not
post new threads
You
may not
post replies
You
may not
post attachments
You
may not
edit your posts
BB code
is
On
Smilies
are
On
[IMG]
code is
On
HTML code is
Off
