Thread: CC is .5 ppm....algae bloom?
    Default Re: CC is .5 ppm....algae bloom?
    CC of 0.5 doesn't necessarily mean algae, it just means there's something in the water that the chlorine is killing. If it gets to 1.0, or if your water starts looking hazy, then I would shock the pool. If the CC isn't rising, and you're keeping your chlorine where it needs to be, then don't worry about it.
    sabres07 is offline Registered+ Thread Analyst sabres07 0
    May 2012
    Buffalo, NY
    Ok, thanks for the reply.
    It is just that this is my first year of actually knowing what the heck is going on with pool chemistry even though I have owned my pool for 10 years. The thing I want to know is how to spot a potential algae bloom so I can take evasive, swift action.
    By the way, this site is awesome!
    16'x32' oval 15K gal IG vinyl pool; liquid chlorine; Hayward cartridge filter; Hayward 3/4 hp pump; 3/5/2012hrs; Taylor 2006c; utility water; summer: none; winter: vinyl / water bags; ; PF:8
    Quote Originally Posted by sabres07 View Post
    On a vinyl pool, the sides get slippery first.
    BUT, the universal pre-algae marker is . . . you let your chlorine get low! You should assume anytime that happens, you are on the verge of an algae outbreak.
    Interesting. I actually think on my pool I usually notice the bottom getting slippery first.
    Could be. I wouldn't have noticed, because I've never owned a vinyl pool. It's something I learned from servicing them . . . which I rarely did from inside the pool!
  1. Adding CYA and recurring algae bloom
    By ralph in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-23-2011, 08:31 AM
  2. I picked up an Algae bloom (I think)
    By herb396 in forum Dealing with Algae & Slime
    Last Post: 07-17-2011, 02:18 PM
  3. clear water before algae bloom
    By shub_31 in forum Dealing with Algae & Slime
    Last Post: 07-14-2011, 09:24 PM
  4. Cloudy water...then very small amount of algae...then algae bloom
    By Allan in forum Dealing with Algae & Slime
    Last Post: 07-12-2011, 09:49 PM
  5. Cloudy water after algae bloom
    By Robin N in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-05-2006, 12:50 PM
