I was "2 liner blocks" off on one side. It was a low side so the water was higher about a quarter the way around the pool. Made me extremely nervous, but everyone that saw it reassured me I'd be fine. Well it rained pretty good last night and those 2 liner blocks disappeared and the water was to the top on that low side. Thankfully we have a sewer type drain in our back yard on that side right in the middle of the low side.
I noticed one leg was trying to kick out to the left (and it did some) because it was up against the sod wall that was left behind when the ground was dug out. So, physics took over since it couldn't kick out straight, it kicked to the left. Then I noticed about 4 legs over (using to judge distance) the wall seemed to be leaning in as in wanting to buckle from the low side of the pool being so heavy and the legs not being able to move. That was it, I started draining and am starting over in the morning! Luckily I have room to move the pool to the left and back some. Not much, but even 2 inches back away from the sod wall should give the legs more adequate room, I hope!
Good luck with yours, I almost convinced myself that there's only a month left so we should be ok. Your's doesn't seem half as bad as mine thou with it being only one corner, but you'll know for sure when your sitting on the outside of the pool and there are people in it and you see the movement of the legs and walls. That's how I determined no way can I take the chance. While my son swam this afternoon, The more movement in the pool the more the leg seemed to shift and the wall leaned in. I also noticed the liner was bulging at the bottom (outside of the pool) on that low side and the seam was no longer at the bottom of that wall but seemed to be moving towards the middle.
