Results 1 to 4 of 4
Thread: Cloudy Water
    Jul 2012
    Niagara Falls, NY
    Default Cloudy Water
    My 24 foot above ground pool took about two weeks to get sparkling clear after I opened it in May. However two weeks later it started to cloud up in spite of maintaining chlorine levels including shock once per week. I attempted a number of things and then it started turning green - not slimed up but definitely green and even more cloudy. It has been very hot and dry here for over a month so that may have led to the problem in the first place, but it seems that my efforts should have worked. Here is what I've tried:
    1. Chemicals properly balanced? Check. At least as best as I can tell from reading my test strips.
    2. Lots of shock - 4 gallons in the evening into about 13,000 gallons of pool water. That eliminated the green but not the cloudiness.
    3. I put a blue clarifier called Sparkle Super Clarifier into the skimmer as perscribed. It claims to be a combination flocking agent and an improver of my sand filter's (200 lb) performance. The bottle says it cannot be over dosed, so I thought it would be a safe one to use. Didn't do anything. Added more the next day and ran the filter until nighttime at which time I shut it off to aid in settling of precipitates. I vacuumed the next day. Still cloudy!
    4. I've read that if the PH is on the high side of OK, lots of shock can contribute to the cloudiness, so I lowered it a little - looked to be about 7.2 after doing that. No luck.
    5. Even after subsequently keeping chlorine levels high, it started to turn green again so I added four more gallons of shock plus two pounds of the dry shock. The water is blue once again but STILL CLOUDY!
    6. I'm currently putting in daily maintenance doses of algecide to hopefully prevent the green as well as maintaining chlorine levels on the high side.
    I replaced the sand this season, vacuum regularly and keep trying the above. I've backflushed but not overdone it since literature seems to indicate that overdoing that can reduce the filter's effectiveness. The only thing in the PoolSolutions Gotchas list that might apply here is the clarifier being the culprit in which case the claims on the bottle that it cannot be overdosed are false. Any thoughts?
    Default Re: Cloudy Water
    It's hard to tell what all might be going on, because you've done so many things. Do all these things:
    1. Dose with PLAIN 6% household bleach EACH evening -- 2 gallons per dose. Do NOT use other forms of chlorine, till you have completed pH, alkalinity, hardness, and stabilizer tests.
    2. Get an OTO test kit ASAP -- HTH 6-way OR a cheapie, if the 6-way is not available.
    3. Get a K2006 (see link below).
    4. STOP using algaecides EXCEPT polyquat
    5. STOP using clarifier.
    6. Report test results when available.
    7. Increase evening bleach dose in 1 gallon increments until you are able to HOLD a dark yellow OTO result till the early AM.
    8. BRUSH the pool completely the 2nd evening. Add at least 1 extra gallon of bleach AFTER brushing.
    9. Get a small amount of DE powder. As soon as you water is clear enough to allow you to do so, add ~2 cups of DE to the skimmer, and then watch the return jet. If you see DE powder blow back into the pool, REPAIR your filter.
    Remember that with algae, you are always either winning or losing . . . and if you're NOT winning you ARE losing, even if it doesn't look like it at first. Algae always either dying, or getting worse: there is no stable condition if algae is present.
    Good luck!
    Jul 2012
    Niagara Falls, NY
    Quote Originally Posted by PoolDoc View Post
    Good luck!
    Thanks. Looks like I have some work to do.
    24' AG round
    It's much harder to cleanup pools, than to maintain them. Unfortunately, pool stores have NO incentive to encourage people to do so, or teach them how. They can make more profit from one algae episode, than from a whole summer of generic chlorine.
  1. Cloudy water
    By Vlmac55 in forum Dealing with Algae & Slime
    Last Post: 07-19-2012, 08:31 PM
  2. Cloudy Water
    By joserq in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-09-2012, 01:01 PM
  3. Cloudy Water
    By ComeShareACupofTea in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-06-2011, 11:49 PM
  4. CLoudy Water
    By Sunshine427 in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-01-2008, 03:57 PM
  5. Cloudy Water & Water Behind Liner
    By cschnurr in forum Dealing with Algae & Slime
    Last Post: 09-19-2007, 09:04 PM
