Results 1 to 8 of 8
Thread: 475 gallons, how much powder "Ultra Shock" to use??????
    Jul 2012
    Maryland
    Exclamation 475 gallons, how much powder "Ultra Shock" to use??????
    Finally got a larger pool then we've ever had, but it's still small. 475 gallons. Has a 300 gallon pump/ filter that came with it. I have no clue how to take care of anything like this without completely draining it, scrubbing it and re filling it every time and that's a huge job with a bigger pool like this. I just want it to stay as clean as possible without having to completely drain the darn thing....while also being safe for my 3 kids under 7 years old. I went to a pool supply store and the lady sold me a $5 1lb bag of "Ultra Shock" powder. She said to get this kind because it is 97% chlorine instead of having added shellfish fillers that cloud the water. Anyway, it's like trying to find a needle in a haystack getting an answer to this question, I guess because everyone else has bigger pools. This bag of chlorine powder has no directions on it for small pools and the lady said to use 1/2 pound (1/2 bag) for my pool. Does this sound right? I am really scared that I will over chlorinate and don't want to poison my kids. I have no idea what I'm doing. HELP.
    Thanks guys
    -Shannon
    Default Re: 475 gallons, how much powder "Ultra Shock" to use??????
    These little tiny pools are harder to give doses for. Let me ask PoolDoc to take a look at your question for you.
    Welcome to the Pool Forum!
    Jul 2012
    Maryland
    Thank you so much. Just really scared she sold me something too strong. Wondering what's the safest thing to use for small pools like this, I know I'm not the first to have one and someone must know lol.
    OK. Treatment for a 500 gallon mini-pool.
    1. Get a cheap OTO/phenol red test kit at Walmart.
    2. Buy 2 gallons of PLAIN 6% GV bleach.
    3. Buy a 4.75 lb box of borax
    4. Buy a container of spa acid, or get it from Amazon.
    5. Buy anything you can't find, plus the other items, from Amazon.
    Then do this:
    Start-up treatment
    1. Drain and refill your pool.
    2. Add 1/2 cup of bleach; add 1 cup of borax; add 1/2 cup of dry acid.
    3. Mix completely and test.
    => If chlorine is not > 3 ppm, add a 2nd cup of bleach
    => If pH is greater than 7.8, add 1/8 cup of acid
    => If pH is less than 7.2, add 1/4 cup of borax
    => Wait 1/2 hr and retest. Add again, as needed.
    4. Once everything is adjusted, move to daily treatment.
    Daily treatment:
    1. Test pH and chlorine each AM, and add 1 teaspoon of polyquat.
    => If pH is greater than 7.8, add 1 tablespoon of dry of acid; if pH is less than 7.2, add 1/8 cup of borax
    => If chlorine is less than 1.0, increase your PM dose by 1/8 cup of bleach; if chlorine is greater than 5 pm decrease your PM dose by 1/8 cup
    2. Add 1/2 cup (plus/minus adjustments) bleach EACH evening, within an hour or so of sunset.
    3. Add 1/4 cup of bleach after EACH swim period.
    4. Drain and refill every 2 weeks, if you are swimming regularly.
    Walmart items:
    HTH 6-Way Test Kit if available; otherwise whatever OTO / phenol red kit they have.
    PLAIN 6% household bleach (Walmart Great Value bleach) => big box store brands are preferable,
    since they are (a) usually 6%, & (b) not mixed with goop, like some Clorox blends
    20 Mule Team Borax
    granular spa or small pool acid?
    plastic measuring spoons and cups -- use SEPARATE measuring containers for acid and chlorine.
    Amazon items:
    Polyquat info & purchase link
    Kem-Tek Dichlor 2.5lbs
    Leisure Time 22338 Spa Down, 2-1/2-Pound
    Read the Intex recipe, in this section. If you buy some dichlor, we'll help you with doses. Dichlor would be easier than bleach, but you'll have to buy from Amazon to be sure of getting un-gooped-up dichlor.
    Jul 2012
    Maryland
    OMG, holy cow. Ok, wait. As I definitely appreciate the time you put into that reply PoolDoc, I am not looking to start a laboratory, nor spend any more money than I already have (recently divorced Mom of 3 and funds are limited . This is crazy lol. I just want to know what ONE powder or ONE liquid I can use to treat a 475 gal pool once a week to keep the water clear, and how much is a safe amount. Want to keep it that simple. I've already spent money on the Ultra Shock powder, can I or can I not use it at all?
    WOW, what have I gotten myself into?? This is a $45 kid pool! LOL
    Quote Originally Posted by Shannon84 View Post
    Yep. So do lots of people. And pool stores LOVE to sell folks that 'one perfect ingredient' -- though if you read the fine print, you'll find that they don't actually claim in any legal manner, to do what you want. That way, you can't sue. And, they can sell you ANOTHER 'one perfect ingredient', when the first doesn't work.
    I'm gonna be frank: your problem is,
    (a) it's HARDER to keep a 500 gallon pool safe and sanitary, than it is a 5,000 gallon pool, and
    (b) the laws of chemistry, physics and biology won't re-write themselves just because you don't like their effect on your life.
    Albert Einstein is reported to have claimed that when he explained things, he tried to make the explanation "as simple as possible, but no simpler!". We try very hard to make pool care as simple as possible. But, you want it to be SIMPLER than is possible.
    No can do.
    But, if you insist on keeping it "THAT" simple, add 1/2 cup of bleach every evening, and 1/4 cup every time someone swims, and drain the pool weekly. That may work out OK, and at least it will reduce the chance of someone getting sick. It's not really an adequate method, and if you have more than 2 or 3 people in there, it may not be safe. I wouldn't let MY family in your pool!
    But, it will be safer than doing nothing.
    Good luck!
  1. Need to shock after "Babe Ruth" incident?
    By KaseyNewman in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 04-23-2012, 06:24 PM
  2. What would "shock level" be considered?
    By cooper in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 04-15-2012, 02:45 PM
  3. Can a leaking Jandy "Check Valve" with clear top be "fixed"?
    By 105ex in forum Pool Equipment & Operations
    Last Post: 05-29-2010, 09:17 AM
  4. when is it safe to swim after "shock"?
    By kjmelak in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-06-2006, 08:47 AM
  5. Esther Williams "Millenium" Pool Install "issue"
    By mrpurrhead in forum In-Ground Pool Construction and Repair
    Last Post: 06-12-2006, 11:34 PM
