Just use bleach for your daily chlorine. With a CYA of 72 (how did you get that number??), you need to keep your chlorine levels between 5-10 all the time. You do not need to use algaecide and you also do not need to routinely shock unless you are having a CC reading greater than 0.5, cloudy water or see the beginnings of algae. If you maintain your chemistry properly, you rarely need to shock.
