Results 1 to 10 of 13
Thread: Pristine blue to chlorine
    Default Re: Pristine blue to chlorine
    I'm sorry; we usually tell people to get a kit, but in this case we missed it.
    + Here are links to the kits we recommend:
    HTH 6-Way Test Kit @ Walmart
    Taylor K2006A (3/4 oz bottles) @ Amazon
    Taylor K2006C (2 oz bottles) @ Amazon
    You need to find out your CYA levels, to help us answer your question. But, in general, you still need to chlorinate if you can't hold chlorine overnight. Rapid chlorine loss during the DAY usually means low / no stabilizer.
    HOWEVER, you do NOT want to "shock" the pool, or add a lot of chlorine all at once, till you are fairly sure little or no copper is left. A large dose of chlorine will tend to cause the copper to stain!
    Jul 2012
    Maryland
    Thanks...
    I got a kit and here are my results...ph 7.5, cl 1, br 2, hardness 80 ppm, alkalinity 90ppm...and my water is clear and beautiful!
    But here is the one you were mentioning...(by the way you are sooo correct!) i could NOT get the cya to turn cloudy so i could not get a reading...so I'm guessing my CYA is too low and that is why I can't get the chlorine level up????
    Thanks for the info about "shock" I will NOT add the jug of "Shock" that the pool store sold me with my pristine blue. ( I called it shock b/c that is what is on the label but I am listening and I do understand now that shock is a process not a product.)
    So please tell me what to do now..
    Your chlorine level is fine for a pool with no CYA -- read the Best Guess page in my signature.
    To add CYA you can EITHER add stabilizer directly or you can use dichlor for awhile. I'll put links for both below. Do NOT buy dichlor locally except at Sams -- you'll need to become an EXPERT chemical label reader before you tackle that. Stabilizer is usually still unblended, but even that is changing, so be careful. Adding dichlor is easiest.
    Ben
    + If you need stabilizer, and have access to a Sams Club, buy their 24 pack of 1# bags of dichlor shock. Each bag will add about 7 ppm of chlorine, and about 6 ppm of stabilizer, per 10K gallons of water. Otherwise, order dichlor from Amazon:
    Kem-Tek Dichlor 22 lbs
    We do NOT recommend buying dichlor locally, otherwise, at least until you are an EXPERT reader of chemical labels. The chlorinating pool chemicals sold at Walmart, Kmart, Costco, and most other local stores are diluted blends, sometimes with copper and other products with bad side-effects.
    Jul 2012
    Maryland
    Ok...went to Sams...Now What??
    I'm assuming you mean that you went to Sams Club, and bought their dichlor?
    If so, start dosing your pool with dichlor at the rate of 1/3 lb or 3/4 cup, per dose. Make sure NOTHING is in your skimmer or feeder -- no tabs, pills, gizzmos, etc -- and then add the dichlor directly to the skimmer, while the pump is running. Make sure the pump runs for at least 1/2 hour after each dose.
    You can add multiple doses in one day, but space them out. Adding too much at once is more likely to result in any remaining copper turning into stains!
    Once you've added a total of 4 lbs, you'll have about 20 - 25ppm of stabilizer, and should begin to see your chlorine last longer. Here's how to track your stabilizer level:
    Lbs added = CYA ppm
    4 -----------> 24
    8 -----------> 48
    12 ----------> 72
    (for ~10,000 gallon pool)
    Evaporation won't lower your CYA, but splash out and leaks will. However, before you get to 10 lbs of added dichlor, let's work out an over all treatment plan for your pool. OK?
    Meanwhile, read the Best Guess page linked in my signature, so you kinda get to understanding it, before you have to do so.
  1. Want to switch from Pristine Blue to Chlorine
    By SandSpringsGrandma in forum --cleanup--
    Last Post: 06-19-2013, 11:12 AM
  2. Pristine Blue stained my pool and I want to switch to BBB /Chlorine
    By efxs25 in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 06-02-2013, 06:41 PM
  3. Convert FROM Pristine Blue to chlorine
    By johnmjankowski in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 05-30-2013, 01:49 PM
  4. Want to convert from Pristine Blue to Chlorine
    By Michelle W in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 05-07-2012, 09:02 PM
  5. Pristine Blue to Chlorine?
    By Kreebog in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 05-19-2006, 06:53 PM
