Thread: adding bleach
    Jul 2012
    North Carolina
    Default adding bleach
    Whats the best method for adding bleach to bring up chlorine level in an above ground, 24 ft round pool with vinyl
    liner?
    Default Re: adding bleach
    Just pour it in. It will be distributed faster if you pour it in front of a return.
    And . . . if you are ABSOLUTELY sure you have no chemicals in the skimmer and no feeder of any kind in the piping anywhere, pouring it in via your skimmer will clean the filter sand, which sometimes gets full of algae and bacteria.
  1. How often should I be adding bleach?
    By Charles in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-27-2011, 01:45 PM
  2. Adding Bleach Method
    By Deuce2 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-16-2008, 05:58 PM
  3. Adding Bleach w/CYA in skimmer?
    By JJParrish in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-07-2007, 04:46 PM
  4. Adding Bleach - frequency?
    By BarryY in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 11-08-2006, 05:55 PM
  5. Question on Adding Bleach
    By jrv331 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-19-2006, 10:41 AM
