Results 1 to 10 of 19
Thread: How to properly chlorinate small 12'x30" intex pool? And few other questions.
Threaded View
  1. #7
    Default Re: How to properly chlorinate small 12'x30" intex pool? And few other questions.
    Thanks for filling out the chart. The 6-way kit you bought only has enough reagents in it to test CYA 2-3 times. We know there's none in your tap water, so don't waste the reagent testing that. We DO, however, need to know the CYA level in your pool water. And.....if you tell us the ingredients in the granules you already have, you might be able to use them, too. In the meantime, stay with the bleach. A little bit of bleach can do miracles in a pool!
    Edit: Need to know CYA in pool, not in fill water!
  1. New member w/ small Intex pool, looking at salt systems
    By Air_Cooled_Nut in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-21-2013, 06:53 AM
  2. Intex pool "old" stock
    By SafetyBob in forum Intex-type Pool Setup & Operations
    Last Post: 02-22-2013, 10:20 AM
  3. small intex 2,000 gallon above ground
    By luvmypool in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-21-2012, 10:26 PM
  4. intex small 8' x30"
    By flprobsolver in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-10-2012, 05:53 PM
  5. Small "BB" sized hole in my above ground pool wall
    By The Raddish in forum Above-Ground Pool Construction & Repair
    Last Post: 04-19-2006, 11:31 AM
