Hi:
We have an above ground (vinyl) pool, about 80,000L, with a sand filter. The water temp has been quite high for over 7 days now, holding around 88 - 90 F. Chlorine has been in the recommended range, but I'm wondering if I should bring it up to 3ppm in the hot weather?
Lately, I've noticed in the water a lot of tiny tiny bubbles and if you look into the reflection of the sun, you can see a slight fizzle on the surface.
The water is still clear from outside looking in, but if you're under water with goggles, you can see a lot of tiny tiny bubbles in the water.
I know we have a bit of an air leak from our solar heater, but no where close to the volume of bubbles in the water. Could it be something else?
