Just posting back to inform everyone that the system I have is a Fiberstars model 2008 illuminator box, the lens and lens housing will need replacing most likely but it seems to be hard to match the specific model parts. By the way... according to the manufacturer: All fiber optic systems are never sold to homeowners and most pool builders/contractors know nothing about them, however, they are extremely simple to get the hang of and very easy to install a single endglow system (google is your friend).
I also wanted to add that I noticed someone posted in the electrical section of the forum about using their fiberstars system with a cracked rotating glass piece (which the bulb shines through). I just wanted to say that YES they can still use the light, the glass will still rotate under the light and they will generally get the same effect but the color disc can easily be replaced if they order the part directly from the fiberstars website. If you are able to pass that information along I am sure they would appreciate it. I would post myself but I don't seem to have permission to do so, I don't mind... but I do hope this helps. Now that I have some experience (I also have all the model diagrams and install manuals with part listings) I will be able to help others since this seems to be a common lighting system. I am more than happy to email/send/direct anyone to the pdf files that have model information and install instructions. It's actually something people should research more even if they don't normally deal with these systems because they are becoming more and more common. Thanks again![]()
