Re: Testing results
After a good amount of lower, refilling as to not go low on salt, I was finally able to get the unit to operate where it's working without a low/high salt warning going off. Added acid and CYA (sock) then let the unit operate for 2 hours like the manual suggests for my size pool.
Here are the testing results taken this morning at 7:30.
TC 5
Ph 7.2
ALK 260
Hardness 280
CYA 50
I am also using a solar cover during the daytime.
13' X 39" Metal Framed AGP with an Intex 1600 gph pump, 14" sand filter and SWCG. Have to start somewhere....
