Re: Just chlorinating is NOT working.
Ok so I'm pretty sure it's the metal. I have very bad rust stains in my house from our water due to a high iron content. When i do backwash my filter it is green at first but turns a brown color. When i vacuum my pool i get a light green color when i hit the light spots but when i go over the heavy spots its very dark almost brown. The sides are not slimy at all, but the bottom can fell a little but more gritty than slimy. When i cleaned it today it looked as if the water was brown coming out of my out flow. I've heard that metal does not get trapped in a filter. What can i us to get rid of it???
Do the CuLator metal removers work or should I use one of the liquid metal removers?
24' round 14.5K gal AG vinyl pool; bleach 6%; SwimPro High-Rate Sand Filter Model# SW236T sand filter; Century Pool / Jetted Tub Motor HP 1.0 pump; hrs; Chlorine/Ph from Walmart right now. Will be ordering the one suggested shortly though.; ground water; summer: none; winter: vinyl / water bags; ; PF:8.3
