Results 1 to 10 of 10
Thread: Changing Sand
    Jun 2012
    Tennessee
    Default Re: Changing Sand
    ok..i was way off pool is 5yrs old. its 16x32, 20,000 gallons. my ph is is always between 7.2 - 7.6 my chlorine level is always 1.0 - 1.5. i use aqua chem shock..sodium dichloro-triazinetriorie. there is no visible algae. my local pool supply store says i need to change my sand every 3 to 4 yrs..confused?
    Your pool store is wrong, you do not need to change your sand. I recently bought a new filter. The one I had previously had the same sand in it for 12 seasons and it was fine for many more years. I sold that filter and the guy who is using it is still using that sand.
    We need to know your CYA reading. A chlorine level of 1.0-1.5 is too low for a pool that is using dichlor. Dichlor has CYA in it and it builds up over time. Chlorine levels are based on CYA levels. The more CYA you have, the more chlorine you need to keep algae away. I have a feeling this is your problem. Take a look at the Best Guess Chlorine Chart in Janet's signature above for more info about that.
    Jun 2012
    Tennessee
    This is foreign to me. What is CYA reading? I am having to backwash and shock ever other day and the green comes back. Ive never had this much trouble with the pool.
    CYA is the same thing as stabilizer--it sort of acts like a sunscreen for your chlorine. How high you need to take your chlorine levels depends on your CYA level. Once you know, and achieve your shock level, you have to maintain that level until the algae is dead, and until you can go from sundown to sunup without losing any chlorine.
    If you've been using dichlor -- a stabilized form of chlorine -- it's VERY likely you have rather high levels. The "Best Guess" page linked in my signature explains what's going on. You will have to have a K-2006 test kit (test kit info page ALSO in my sig) in order to measure and manage your pool levels. (There are other kits, but they cost more) Dealer testing is usually NOT trustworthy, and the only way to tell if your dealer is the exception to the rule, is to test it yourself and compare. But, once you can do that, you don't NEED his testing.
    Jun 2012
    Tennessee
    I see your in Chattanooga...can you just come fix it for me. lol What is your take on changing sand?
    No, no, no.
    I try to keep a low profile here -- I don't want to get crucified when I go to the local wholesalers!
    (Besides, I've operated pools that had 40 year old sand, that worked fine!)
    I keep my local identity pretty separate from my online one. My one remaining local customer just found out that I have a somewhat well known online presence -- and I've been working for them nearly 20 years!
  1. need advice on changing out my zeobrite to regular sand
    By pbotz2000 in forum Pool Equipment & Operations
    Last Post: 06-15-2013, 12:45 AM
  2. changing filter sand
    By jrtvols in forum Pool Equipment & Operations
    Last Post: 07-02-2011, 07:44 PM
  3. Changing filter sand
    By tado921 in forum Pool Equipment & Operations
    Last Post: 06-03-2008, 10:10 PM
  4. help needed with changing sand in filter
    By chemstick in forum Pool Equipment & Operations
    Last Post: 06-14-2006, 07:04 AM
