I put up an 18' x 52" Intex pool last week. Filled it from the hose (public well water), roughly 7,600 gallons. Until it was about half-full, it appeared clear and clean, but after it got about 3 feet of depth to it, it began to appear green. Once full, the water was light green, but clear (not cloudy). First thing, I did a strip-test. As suspected from past experience, our alkalinity was off the chart high. In the past, we had alkalinity problems, and after trying several different methods over the course of an entire summer, I finally learned that I needed to treat the water with a gallon of muriatic acid to bring it down and keep it down. So, 1 1/2 gallons of muriatic acid, ran the filter overnight and 24 hours later, the alkalinity was 100. I shocked it and 24 hours later, I tested again and got:
TC 5
FC 3
Alk 120
PH 7
hardness 100
Water was still green and clear. I changed the cartridge, added algaecide, and ran the filter for 6 hours, let it sit for 8, vacuumed, still no change. I changed the cartridge filters every 6 hours and ran the filter 12 hours a day for a few days and with no change, I took a sample to the nearest pool store to test yesterday.
FC .16 ppm
TC .16 ppm
pH 6.6
Hardness 102 ppm
alkalinity 100 ppm
cyanuric acid 8 ppm
copper .1 ppm
Iron is 0 ppm
She did a separate test and found that our phos level was 1,000.
She gave me a degreaser to clean the cartridges with, and had me start with a clean cartridge last night, added 32 oz. of Metal Klear, put a chlorine tab in a floater and another tab in the skimmer basket and ran the filter for 6 hours, then let it rest overnight. Changed the cartridge this morning, and vacuumed the pool floor. I disassembled the skimmer and thoroughly cleaned it (it had an odd film that had built up on it (not slimy, but almost powdery, cleaned off very easily with a paper towel). Changed the cartridge AGAIN, and let it run for 8 more hours. I'm a few hours into that wait and still see absolutely no difference in my water at all.
Does anyone have ANY CLUE what this could be caused by or have any ideas? Please help?
