You have no bromine readings, unless you've added bromine. If you have a new K2006, you should have everything shown in the video. And, you wouldn't be getting a TC result; you'd be getting a CC result, and have to determine TC by addition.
I assume you are matching colors, to determine chlorine? That's K2005, not a K2006. But, even a K2005 should have EVERYTHING shown in the CYA video here: www.youtube.com/watch?v=8whkC5WtS8g
I'm not quite sure what's going on with you, or your pool. I think we both need to step back, and reconsider.
I'd suggest that you add 1/2 gallon of 6% bleach to your pool and cover it. That will keep it for a few days.
Then, let's figure out what sort of test kit you have, what you are measuring, whether you want to follow BBB approach to pool chemistry . . . and then whether you have the stuff on hand needed. I think we are both just spinning our wheels at present.
