Lets see the green is (was up until 2 days ago now it is a little darker I can't see the bottom) a see thru green (I could see the bottom, but water was green- If I', looking where water blows back into pool the water looked orangish green (if that makes sense)) so last night I got the clorine level up into the orange range well above what my test kit reads (only goes up to 5.0 a bright yellow- it's the test kit with the drops). I know there is high iron in water possibly copper from pipes, pool was filled by outside faucet which is not connected up to my water softner just straight from well.
so from begining it took a week to fill the pool (water was slightly orange- see thru) by the time the pool was full enough to run filter/pump it was starting to turn green (the see thru green). threw in baking soda, 1/2 bottle of seaklear from last year and a bag of shock plus didn't do anything. had pool store test water, they said add a full bottle of the seaklear and a pound of granular chlorine and filter filter filter after I did that nothing was coming out on my filter cartridge not even the orangish stuff from the iron that I suspected was still in the pool. so my husband said to forget the expensive chlorine and use bleach so I threw in 2 1/2 gal of bleach and 2 box baking soda. still nothing if it's algae it doesn't seem to be dropping no matter how much chlorine/ bleach whatever I put in. so I thought maybe the filter isn't big enough I thought it was an upgrade from the 1600 gph sand filter that came with it (since it suposidly filters 2500 gph and again with my iron issue I figured maybe would be more practical than the sand one, but now I'm not sure. is there a bigger cartridge pump than the one I have I seen a 4000 gph on the web but noone seems to have them to purchase. What should I do? Thanks
