Results 1 to 10 of 33
Thread: Chlorine block-need recommendations
    Default Re: Chlorine block-need recommendations
    You do NOT want the CYA granules in the folds of your System 3 beast cartridge!
    . . . if it's not too late . . .
    Jun 2012
    Maryland
    Too late. I will go pull it out now. So we would use the dichlor instead?
    Wait, you said prior to put it in a sock in the skimmer that's what I did with the uv shield...wrong? Ordering dichlor today...
    20'x40' Double roman 24K gal IG pool; Skimmer tabs; Sta-rite s7m120 cartridge filter; Hayward sp2015x20 pump; 24hrs; Taylor 2006 c; delivered via truck; summer: ; winter: ; ; PF:5
    If the DE was in a sock, it's fine.
    Jun 2012
    Maryland
    Phew ok
    Jun 2012
    Maryland
    Can we swim during the day if we are putting in bleach at night? Should we bleach nightly until we hold chlorine during the day? Also, how do I become a full member of the forum, is it a paid by year type thing? Mid love some insight on opening and closing the pool ourselves when the time comes. Thanks again for all of the help!
    Subscription link is in my signature.
    You can swim during the day so long as there is still SOME chlorine in the pool; if not, you need to add a small dose.
    Jun 2012
    Maryland
    I'm sorry for my ignorance, but how much of a dose do you think? I had subscribed to the forum but when I went to look at other threads i couldn't access...
  1. Chlorine Block?????
    By JoyceMarie in forum --cleanup--
    Last Post: 06-07-2013, 04:10 PM
  2. Concrete block method
    By tybeeware in forum In-Ground Pool Construction and Repair
    Last Post: 06-22-2006, 04:53 PM
  3. Chlorine Block?
    By sandysfreckles in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-05-2006, 11:57 PM
  4. Patio block question
    By NWMNMom in forum Above-Ground Pool Construction & Repair
    Last Post: 05-08-2006, 06:53 AM
