Re: Phosphates
					Phosphate are not a problem. They come form several sources such as fertilizer and breakdown of some pool chemicals. They can be algae food but so is nitrate. However, the pool store will not say anything about nitrate because the only way to lower it is by changing water so they can't sell you anything and make money. If you maintain your chlorine level properly you will not get algae, need to shock weekly, or need phosphate removers. If you don't they might be a temporary band aid but will not solve the problem. Interesting thing to think about...how did anyone manage to keep a pool before phosphate removers hit the market a few years back? Answer...by properly maintaining their chlorine levels.
Anyway, the raw material that is used in all the phosphate remover products (lanthanum chloride or other lanthanum salt) has recently increased in price so I expect you will start seeing a lot less interest in selling you a phosphate remover since it will not be as profitable. There is already a replacement "Problem" and "cur"e that is starting to make the rounds...biofilms and the products to remove them (which include propriatry mixes of soda ash and sodium metasilicate, enzymes, sphagnum moss-npt joking!, and other such snake oil! They do all have one thing in common, they are all used in conjunction with chlorine..see where I am going with this?)
Do you see where I am going with this?
