Thread: Muriatic Acid in small pools?
    BigDave's Avatar
    Default Re: Muriatic Acid in small pools?
    pH minus = Dry Acid = Sodium Bisulfate. Dry Acid will lower your pH, it just adds sulfur to the pool - OK in small amounts. It's eaisier to handle than Muriatic Acid and in a small pool that wil be drained annually shouldn't become a problem. It's also available in small quantities and requires no special storage arrangements. Less is more - use a little then a little more to creep up(down) on your pH goal. Dissolve it in a bucket of water and add it to the pool and let it mix for a couple hours and test again.
    Jun 2012
    IL
    thanks that is what I am trying
    do instructions stay the same
    lower PH just ad and run filter
    lower ph & alk ad and aerating the water.
    my filter does not aerate so I put a fountain pump in overnight
    also at what point to I get to reply and post in regular forum?
    thanks
    Ben will eventually upgrade your registration so that you can reply and post in the whole forum. We've just been completely swamped with new posters with questions, so he's running a bit behind on the admin stuff trying to help get everybody swimming. You can search and read the forum using the google search link in my sig, but you may have to log out to read the threads until you get upgraded.
    Jun 2012
    IL
    OK had MY PH and alk down but I never can keep chlorine in it. I can put a double daily dose of the 62% granulated chlorine per the "Kiddie Pool Chemical Shopping List" and calculator and it never shows up on my HTH test so I give it 3/4 cup of bleach and that works but it is gone the next day
    Do you have any idea what your CYA level is? Without CYA in an outdoor pool, it is impossible to keep chlorine in a pool. Do you have a test kit?
    Please fill out the information in the following chart. It will help us better to be able to help you.
    Pool Chart Entry Form
    Pool Chart Results
    Also, we suggest getting a good kit. The one we recommend is the Taylor K-2006 or 2006C which you can get through the testkit page in my signature.
  1. Can anyone tell me where to buy muriatic acid?
    By blessedbeingmom in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 04-06-2011, 01:35 PM
  2. Where to get 31.45% muriatic acid?
    By laughingboy in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-30-2010, 11:31 AM
  3. Lowering TA with Dry Acid Or Muriatic Acid
    By CelticDaddio in forum Dealing with Alkalinity and Calcium
    Last Post: 07-05-2007, 12:54 AM
  4. Muriatic Acid
    By Simmons99 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-04-2006, 08:07 PM
  5. How to add muriatic acid
    By BullDean in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-12-2006, 10:51 PM
