Hello to everybody,
I decided to give your forum a try, before I'll mess up my pool water again. My husband and i we purchased a house with above ground pool (24 feet round pool with 14,000 gallons water). It's the second time when we had to drain the water because improper balance of water witch caused us a lot of problems .At this moment , after we fill up the pool, I added 1.5lb hth stabilizer and conditioner, and my readings are the following:
FC 0.15
PH 7.7
TA 101
TH 147
CYA 9
My question is, How can I adjust the water balance, before I'll mess it up again?
The readings were made at the pool store, I only own the 6 way test strip.
