Results 1 to 10 of 62
Thread: slimy, gelatinous strings of goo ruin a good dip.........
    Default Re: slimy, gelatinous strings of goo ruin a good dip.........
    Don't do it yet! We've had a couple of failures to remove all the stains, and keep them off, and I want to prevent any more.
    Please do a COMPLETE test with a K2006, and then list EXACTLY what you have on hand, and the quantities. Also, please complete the
    Pool Chart Entry Form
    (If you've already started, tell me what you've done so far, but FIRST lower your pH to near 7.0, if it's not already there!)
    Jun 2012
    New York
    yes, as you requested in post #49, I will do the testing and let you know the results before I buy anything.
    24' round 13K gal AG vinyl pool; hand fed granual; sand filter; hayward power flo LX pump; 8 - 12hrs; hth 6-way test kit; utility water; summer: none; winter: mesh; ; PF:9.2
    Jun 2012
    New York
    STAINS GONE!
    here's what I did.
    No money for all the chemicals suggested so I did a goggle search, read some stuff and proceeded with my own cure.
    I got the chlorine down to nothing, added 3# ascorbic acid and by morning the pool was sparkling and stains were completely gone. Started adding chlorine back in immediately.
    Also added Ph-UP (no borax to be found in any stores....) through filter basket to bring it up a bit (couple scoops as my Ph was still in the 7 range).
    So far----so good. I'll let you know if anything happens to change this miracle! Thanks for all your help.
    You have to watch out. AA will remove the stains -- redissolve the metal into your pool water -- but the metal is ALL still in your pool. Adding chlorine and raising the pH tends to make it come back OUT of your water. Some will end up on the filter, but it's also likely that your stains may begin to re-appear.
    You can minimize this by
    + running your filter 24/7
    + raising the pH and chlorine gradually.
    + using a no-copper algaecide to prevent algae while the chlorine is low.
    Also, because the metal is still in the water (and will stay there until it "stains out" again) you MUST add a HEDP metal sequestrant weekly to monthly, depending on just how high the metal level is and how high you keep your chlorine (HEDP is broken down by chlorine and sunlight) to keep the metal "deactivated' so it does not redeposit back as stain.
    Jun 2012
    New York
    Water still crystal clear, liner sparkly clean. I have the chlorine and Ph back to normal levels for a week now and so far, so good.
    Jun 2012
    New York
    Okay, with this post I am going to close out this thread.
    My pool is still crystal clear after just using the citric acid and slowly bringing Ph and chlorine up to regular levels. Didn't need any of that other stuff. Thanks for all your help.
  1. Opened to a slimy pool:(
    By freddyttt in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-23-2009, 05:14 PM
  2. Brown Slimy Foam
    By cheesemaster in forum Pool Chemicals & Pool Water Problems
    Last Post: 05-05-2009, 12:59 AM
  3. Slimy black goo
    By Sumo1 in forum Dealing with Algae & Slime
    Last Post: 05-02-2007, 12:34 PM
  4. Can Spring Sludge Ruin My Filter?
    By CoffeeBean in forum Dealing with Algae & Slime
    Last Post: 06-09-2006, 08:43 AM
