How much HEDP?
Can I wait until summer's end to deal with stain?
How much HEDP?
24' round 13K gal AG vinyl pool; hand fed granual; sand filter; hayward power flo LX pump; 8 - 12hrs; hth 6-way test kit; utility water; summer: none; winter: mesh; ; PF:9.2
Yes, you can wait till summer's end to remove the stains. However, you might want to go ahead and get everything you need to remove the stains, now, for two reasons.
First, it may be difficult to purchase what you need, in September. --I don't know that it will be, but I do know that many retailers are trying to clear out pool stock.--
Second, if you get it now, you can use small (1/3 - 1/2 recommended ) doses plus a CuLator (under a skimmer sock) to avoid having stains get worse.
From what I can tell from Periodic Products literature the CuLator bags do NOT have a life expectancy -- they are still good, till they've absorbed all the metal they can hold OR are gummed up with pool goo (thus, the skimmer sock).
Regarding the
PoolDoc / Ben
BEN-----HELP!!!
I am now thoroughly confused now with regard to exactly WHAT products I need to get. When I go on Amazon there are just too many similar products. I need a list (with brand names if possible) of exactly what I need. Is this possible?
many thanks. Leyla
Sorry it's taken so long to respond, Leyla.
OK. Do this:
1. Get a bottle of Vitamin C tablets.
2. Put a few on a stained area, wait 10 minutes, remove, and then confirm that the stains are gone. (We don't want to use a stain removal process that doesn't work on YOUR stains!)
3. Do a COMPLETE set of tests on your pool water: FC, CC, pH, TA, CH, CYA, and report the results.
4. Do a metal bucket test on your FILL water -- presumably that's where your stains came from, but we need to check:Bucket-test-for-metalsThen, once we've confirmed that your stains are metal, and that Vitamin C will remove them, you can go ahead and get what you'll need.
I've copied the list of Amazon links that I gave you earlier, and put them below. For your size pool, you'll want
- 2 lbs of ascorbic acid (vitamin C)
- 1 quart of 60% polyquat
- 2 quarts of 20% HEDP or 1 quart of 60% HEDP (corrected!)
- 1 lb of sodium thiosulfate (to remove chlorine)
- 1 package of skimmer socks
- 1 or 2 1.5 ppm Culator units
- 1 gallon of muriatic acid (Lowes)
- 3 boxes of borax (Walmart)
The thiosulfate is not listed below, but here it is: Photographers' Formulary Sodium Thiosulfate, 1lb
Before you buy anything, read the ascorbic acid stain removal page and make sure you understand what you're going to be doing.
Products for metal control and clean-up:
HEDP is a liquid phosphonate that is pretty chlorine stable, and very good at keeping dissolved metals IN the water, instead of ON your pool surfaces. It can lift recent stains, OR it can be used along side of ascorbic acid, to keep the metals in the water, after the ascorbic acid is consumed by chlorine.Jacks Magic The Pink Stuff 1qt (60% HEDP) @ AmazonUsing polyquat during metal clean up accomplishes two things: it helps kill or prevent algae, letting you run lower chlorine levels, and it is a very good clarifier, that helps you filter out any small metal particles that may form.(Probably available from pool stores, and possibly some big box stores -- but you MUST learn to ID it correctly. See the polyquat page for more info.)
20% KemTek HEDP @ Amazon
Kem-Tek 60% polyquat @ AmazonAscorbic acid (Vitamin C) can be used to remove copper and iron stains from pool surfaces, and put the metal BACK into your pool water. (Not likely to be available locally, except as Vitamin pills.)
Nava 60% polyquat @ Amazon
Ascorbic Acid Powder @ AmazonThe CuLator product is a special patented plastic material, contained in a bag that goes into the skimmer, that can slowly take metals OUT of your pool water. We think it works, and have some evidence that it does, but not proof yet. (Not likely to be available locally.)
Ascorbic Acid Vitamin C Powder USP Pharma Grade 11 Lbs @ Amazon1 ppm Culator @ Amazon
1.5 ppm Culator sold by Amazon, shipped from Periodic
4 ppm Culator sold by Amazon, shipped from Periodic
Poolmaster 16242 Poolmaster Skimmer Basket Liner @ Amazon (to protect CuLator from being damaged by scum)
PoolDoc / Ben
Thanks. I'll get back to you after I do what you say. Leyla
Please note correction regarding 20% polyquat, now 20% HEDP!
(thanks, Dave)
The vitamin C pill lifted the stain, so I will proceed. THANKS so much for all your help. More later...........
Don't do it yet! We've had a couple of failures to remove all the stains, and keep them off, and I want to prevent any more.
Please do a COMPLETE test with a K2006, and then list EXACTLY what you have on hand, and the quantities. Also, please complete thePool Chart Entry Form(If you've already started, tell me what you've done so far, but FIRST lower your pH to near 7.0, if it's not already there!)
