For every 10 ppm FC added by trichlor you also add 6 ppm CYA.
I know I've seen it here before, but I could not find it--- so how much CYA does Trichlor tablets add to pool?
And, on a similar note in case someone is interested, with dichlor, for every 10ppm FC added, it adds 9ppm of CYA.
This doesn't make sense to me. I moved to a house where previous owner exclusively used tablets for many years. Sure, CYA ended up being somewhere between 240-300 but shouldn't it have gone up to much higher number?
After the drain and refill, CYA is now somewhere between 70 and 80.
Hopefully this will make it easier for me to keep algaes away. I plan to keep chlorine level between 5 and 10.
25k gal IG pool
PoolDoc / Ben
