Watch this video, and retest: http://www.youtube.com/watch?v=gmpS-...ature=youtu.be
The rest of the videos are here: http://www.poolforum.com/pf2/showthread.php?17157
PoolDoc / Ben
THANKS!!!! That was really weirding me out!!!
16'x30' rectangle 22K gal IG vinyl pool; SWCG; Hayward Pro SEries S220T sand filter; Hayward pump; hrs; Taylor K-2006 ; city; PF:5.5
Hi Team,
An update and questions...test results from earlier this morning are:
pH = 7.2
TA = 90
CYA = 35
FC has been drifting down since mustard algae shock attack. My estimate of FC is 15. I had to use dilution test as I am out of reagent to use with K-2206 test.
Questions:
1) is there a way/procedure to use fewer drops of R-0871 when repeatedly testing FC at mustard algae shock levels?
2) should I continue to lower TA (by adding acid to lower pH then aerating then repeating)
3) When should I add CYA to raise it? I've added several times this summer and am surprised it is as low as 35 but I triple- checked it today
I'm hoping that I have successfully removed the mustard algae but time will tell. No more extended trips away from home/pool should help.
thanks for your continued assistance!
You can use a 5ml sample and multiply drop count by 1ppm. If you have a way to measure 5ml.1) is there a way/procedure to use fewer drops of R-0871 when repeatedly testing FC at mustard algae shock levels?
I see no reason to move your TA.2) should I continue to lower TA (by adding acid to lower pH then aerating then repeating)
Whenever you want to. How do you get 35ppm? Halfway between 30ppm and 40ppm?3) When should I add CYA to raise it? I've added several times this summer and am surprised it is as low as 35 but I triple- checked it today
If you are using the 10 ml sample, then there's no further improvment. However, you can (with practice) learn to eyeball an OTO tester, so you can use it instead. To do so, you'll need to practice by testing with BOTH the FAS-DPD and an OTO kit at the same time.
It's low enough . . . unless you want to do borates, which will make your pool significantly more resistant to algae. Info here:2) should I continue to lower TA (by adding acid to lower pH then aerating then repeating)
http://www.poolforum.com/pf2/showthread.php?18597
35 is pretty low -- if you can get a box of PoolBrand dichlor bags at Sams Club, I'd do that. If not, I've posted links below for Amazon. It's very hard to buy un-gooped-up dichlor otherwise. But the big question is, does your pool leak? That, or excessive backwashing, would be the only reason for dropping CYA levels. (You know you should ONLY backwash when your filter pressure increases at least 5 psi over clean pressure, right? Your pressure gauge DOES work, right?)3) When should I add CYA to raise it? I've added several times this summer and am surprised it is as low as 35 but I triple- checked it today
I emailed you links to your Pool History Chart.
Ben
+ If you need stabilizer, and have access to a Sams Club, buy their 24 pack of 1# bags of dichlor shock. Each bag will add about 7 ppm of chlorine, and about 6 ppm of stabilizer, per 10K gallons of water. Otherwise, order dichlor from Amazon:Kem-Tek Dichlor 22 lbsWe do NOT recommend buying dichlor locally, otherwise, at least until you are an EXPERT reader of chemical labels. The chlorinating pool chemicals sold at Walmart, Kmart, Costco, and most other local stores are diluted blends, sometimes with copper and other products with bad side-effects.
PoolDoc / Ben
Ahh-h.
Simul-responders . . .
BigDave, I don't think there's a 5 ml marked point on the tester, is there? I'll have to go look.
There is a 5mL mark on the tube you get with the HTH 6 way, so is it ok to use that, and have a 1ppm resolution?
15' round 4.8K gal Intex AG pool; Intex 633 pump with twin canisters (2500 gph main filtering); Unicel 5315 filter cartridges; Intex 637 pump w/o filter (1000 gph heater circulation); 4hrs; K-2006; utility water; PF:24
Yeah, if you can see the color change (pink to clear) that would be fine.
