Results 1 to 10 of 10
Thread: dirty water
    Jun 2012
    Ohio
    Default dirty water
    We have 28 ft above ground i can run the pool rover 3 or 4 times and the vacuum sweeper through the pump and pool looks super clean the minute i turn pump on and start circulating the pool looks dirty to me in the bottom we have a Hayward pump with sand filter new sand installed last year please help in Ohio thanks
    Default Re: dirty water
    Love your street name!
    My favorite around here are "Hog Jowl Rd" (in the small town where I grew up) and "Booger Holler Rd" (on the way to a pool I serviced -- it's actually a Cherokee reference, rather than what people think). I hate the faux 'upper class' names builders create, like "Oake Pathe Lane" . . . . or "Willow Oak Drive" . . . in the middle of an old tree-less cow pasture!
    OK. Enough of that.
    Sounds like the dirt is blowing through your filter. AG pools are almost always installed with oversized pumps and undersized filters, when what they need are oversized filters and undersized pumps! With a sand filter, the dirt can be SHOVED through the sand. Also, during backwash the high flow tends to blow the sand out of the filter.
    So, do this:
    1. Open your filter, and check your sand. You may need to add some.
    2. If the filter is low, then you also need to slow the flow through the filter. You can do this by running on low speed (if you have a 2 speed) or by putting a valve between the pump and filter and throttling the flow, or by modifying or replacing the pump or by (best of all) getting a bigger filter.
    3. Complete the pool chart (about 30 seconds) it will make it much easier for us to give you good advice
    Pool Chart Entry Form
    Pool Chart Results
    Jun 2012
    Ohio
    k the pumps a 1.5 hp 1 speed cheaper for a new pump or filter and which one ya recomend when your talking filter your talking complete unit right thanks
    To offer you replacement ideas, short of a complete pump filter combo, I'd need pump and filter MODELS and sizes.
    Jun 2012
    Ohio
    filter is a heyward s210t1580 filtration area f.t-2.2 m-0.21 design flow rate gpm-44 lpm-167 pressure loss at design flow rate-psi-2 BAR- 0.14
    pump power flo l.x series 1.5 h.p it,s a heyward also
    Jun 2012
    Ohio
    still looking for help
  1. Dirty water returns from pump/filter upon startup
    By MJPancoast in forum Pool Equipment & Operations
    Last Post: 07-21-2012, 02:26 AM
  2. dirty water from pump????
    By minermom in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-13-2007, 01:08 PM
  3. Green, Cloudy, Dirty, I got it all in my salt water pool?
    By alexhearn@alx1.com in forum Pool Chemicals & Pool Water Problems
    Last Post: 08-04-2006, 03:24 AM
  4. Jets return dirty water when I vaccum
    By JenniferB in forum Pool Equipment & Operations
    Last Post: 06-12-2006, 01:02 PM
  5. Keeping water clean when removing a dirty solar cover???
    By gonefishin in forum Pool Equipment & Operations
    Last Post: 06-01-2006, 04:00 PM
