Thread: Pond pump for pool?
    Jun 2012
    Ohio
    Default Pond pump for pool?
    I currently have a 30' round above ground pool with a Hayward power-flow LX 1.5 h.p. pump and a Dream Line high rate sand filter. The pump is rated @ 12 amps. I also have a 3000 gallon Koi pond. The external pump I am going to buy for the pond to replace two submersible pumps flows 7750 GPH and is rated at 3 amps. I was thinking of buying two of them and replacing my pool pump with one. Do you think it would be a problem doing this? Thanks for any replies.
    May 2010
    Default Re: Pond pump for pool?
    That sure sounds like pretty low amperage for such a high GPM. What make/model of pump is it?
    Jun 2012
    Ohio
    For some reason I can't find the catalog I was looking in but just doing a quick search online I found the Performance Pro Artesian2 ModelA2-1/2-C. 1/2 HP 3450 rpm 3.3 amps @6660 gph. Most pond pumps that I have found run way cheaper than pool pumps I'm just not sure if the flow is good enough for a high rate sand filter. Not sure how to post links but I found it @ Koi Market.com.
  1. possessed pond pump?
    By docsobeck in forum General Interest
    Last Post: 06-12-2011, 04:11 PM
  2. My pool looks like a pond !
    By crazimom in forum Dealing with Algae & Slime
    Last Post: 04-24-2007, 01:34 AM
  3. Will Pond algae get into the Pool?
    By odqlesz in forum Dealing with Algae & Slime
    Last Post: 07-31-2006, 02:53 PM
  4. Help pool is very green looks like a pond
    By sierrasmom in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-15-2006, 04:44 PM
  5. pool/pond building
    By Michaela521 in forum In-Ground Pool Construction and Repair
    Last Post: 05-04-2006, 10:50 PM
