Results 1 to 10 of 14
Thread: Is this a correct pump to use for a above ground swimming pool
    Default Re: Is this a correct pump to use for a above ground swimming pool
    Dark blond hair is not as much of a problem. But the almost white blonde hair that's pretty common among Dutch children will just about turn green if you drop a copper penny in a pool.
    Watch her hair; if it begins to turn green, you can remove it with lemon juice (citric acid). Then, disconnect the wire to the copper electrodes, and that should solve the problem.
    Jun 2012
    Florida
    Thanks for al those tips. there are very helpfull.
    Can i not Disconnect the wire to the copper electrodes from the beginning?
    And then i will not have this problem thats my daughter maybe gets green hair.
    Quote Originally Posted by qbinflorida View Post
    Yes, absolutely.
    Jun 2012
    Florida
    Ok then there is no problem :-)
    Just buy that set, and then disconnect that wire from the beginning
  1. correct pump for my filter
    By mike in arkansas in forum Pool Equipment & Operations
    Last Post: 07-20-2012, 12:12 AM
  2. Correct Pump Size for Filter
    By RobDHW in forum Pool Equipment & Operations
    Last Post: 05-18-2011, 11:27 AM
  3. HELP! How to pick the correct pump/filter ??
    By darenjones in forum Above-Ground Pool Construction & Repair
    Last Post: 06-25-2007, 12:38 PM
  4. Correct Pump/Filter?
    By cpmart in forum Pool Equipment & Operations
    Last Post: 08-23-2006, 10:34 PM
