Thread: Installing new pump and filter
    Jun 2010
    northeastern MA
    Default Re: Installing new pump and filter
    Per my installer's instructions, I am returning the Tristar (issues w/going from 2" openings of pump to 1.5" of multiport and pool piping, also lid hard to open, rapid gasket failure in his experience).
    So now my conundrum is do I keep original pump housing, step the motor down from 1.5 to 1 hp (or .75?) and replace the impeller and shaft seals or buy a whole new 1 (or .75) hp pump?
    I appreciate anyone's input
    Shynshort (who always over analyzes decisions ;-)
    mas985's Avatar
    Pleasanton, CA
    Given the age of the housing, I would be more inclined to get a new pump. But this time, I would strongly recommend a two speed.
    Since you have two skimmers and a main drain, you might be better off with a 1 HP Superflo. Plus, it is a 230v pump which I suspect is the same as your old pump (?). That way you won't have change the wiring as well. But double check your current pump voltage setup.
    Mark
  1. Installing new filter
    By jv4nu in forum Pool Equipment & Operations
    Last Post: 05-17-2012, 08:15 PM
  2. Question on installing Pentair Cartridge Filter - ABS or PVC?
    By sardelli in forum Pool Equipment & Operations
    Last Post: 06-07-2011, 09:25 AM
  3. Problem with SWG after installing new pump
    By Dixie in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-21-2008, 09:33 PM
  4. Installing a Sand Filter
    By NullQwerty in forum Pool Equipment & Operations
    Last Post: 07-18-2007, 08:57 AM
  5. Installing new pump
    By darrin in forum Pool Equipment & Operations
    Last Post: 07-18-2006, 10:49 AM
