Results 1 to 10 of 43
Thread: White gritty scale
    Default Re: White gritty scale
    Quote Originally Posted by Wapak View Post
    Total alkalinity is reading again at 180, but since I am just starting the aeration I am hoping that will come down.
    That's the opposite of how what you'll see. As you aerate, your pH will rise with little or no apparent change in TA. The apparent change in TA will occur when you add your next dose of acid. Then, the pH will rise again.
    You can simply maintain a pH of 6.8 to 7.0, while monitoring your TA. Once the TA reaches your target, hold the pH there, till the scale is gone.
    But be careful. As your TA drops, it will take decreasing doses of acid to drop your pH.
    Jun 2012
    Ohio
    Oh ok, thanks for explaining that.
    Do you have a suggestion on my target ta number I need to get down to? Or will I know that when this starts coming off in large amounts?
    16'x36' rectangle 21K gal IG vinyl pool; Trichlor feeder, & hand dispense; Fox pools sand filter; A O Smith, Century, 3/4 horse pump; hrs; HTH 6 way test kit, drops; well; PF:5.7
    What I expect is that you'll as you lower the TA, you'll find the scale gradually disappearing.
    Just a caution: your calcium hardness may go UP, as you re-dissolve the scale. And, it may be necessary to either do a partial drain and refill OR do a lime softening process to lower the very high levels of calcium. But you'll be able to use your pool freely before that's necessary.
    Jun 2012
    Ohio
    Ok I tested again this morning, just my chlorine and ph.
    Ph was high, 8.4
    Chlorine was orange, I did shock last night.
    Noticed tho that some very dark almost black spots on the deep end floor that wouldnt brush off yesterday are now gone this morning, finally the water especially in deep end is getting really clear.
    I added a small dose of acid (less than a quart) since yesterday as soon as my chlorine went down, ph holds @ 6.8. Is that enough to add or would you advise a little more?
    I plan on vacuuming, brushing andre-testing midday.
    Also, my T A is turning from green to yellow instead of green to red. So I googled that and it looks like that is due to high chlorine. I will recheck my T A again at mid day.
    Jun 2012
    Ohio
    Just a quick update here at midday:
    Chlorine is now a very dark yellow (was orange this morning)
    ph is now at 7.8
    I did not add anything now.
    The T A test is still turning yellow so I cant provide a number on that yet.
    I didnt have time to vacuum, but I did brush. Definitely some is coming off! As I brushed most of it seemed to settle at bottom, hard to tell how much.
    I will vacuum this evening. I have been vacuuming so far just to waste, I haven't tried sending this stuff into my filter.
    If you have any advice or if I should change what I am doing please just let me know.
    I didnt do it now but this evening I will do a hardness test and provide that number.
    All in all your instructions are working fantastically!. I will do my best to follow exact.
    Thanks again
    + Unless you still have live algae, or unless your CYA > 100 ppm, you don't need chlorine that is that high.
    + I don't remember, and haven't checked, your prior test results.
    + These videos apply, mostly, to the HTH 6-way => http://pool9.net/tk-guide/ http://pool9.net/tk-interfere/ The TA video, in the 2nd set, explains how to test TA when chlorine is high.
    Jun 2012
    Ohio
    Ok PoolDoc, here are my current test results I just took:
    Chlorine. Close to 10just strong yellow now, no orange
    T A: 160- I was able to read, it did not turn yellow as it did this morning. It also was at 180 yesterday when I started aerating.
    PH: 7.5 (it was 8 earlier today)
    I was going to add more acid to again lower ph-do you have any advice on amount? Do to this problem Im not exactly sure how much acid I should be adding??
    Also, I have heavier build up along my deep end seams, its darker in color, I am just wondering if some of that is algae or just a thick pile of the scale? Some of it did go with brushing and vacuuming?
    A pile of this stuff has been coming out my waste hose and filter basket holder-enough to fill a spoon! If you want me to send a picture got a great sample now I could get a pic of!!
  1. white residue or scale in fiberglass pool
    By Poolhouse in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 05-20-2013, 12:18 PM
  2. Prevent white scale on marble
    By dgid0711 in forum Pool Chemicals & Pool Water Problems
    Last Post: 11-29-2011, 12:01 PM
  3. Filter sand: A gritty question
    By Sumo1 in forum Commercial Pool Users, Managers & Workers
    Last Post: 03-15-2007, 12:28 AM
  4. Scale, Scale, Scale!
    By Kricket00 in forum Pool Chemicals & Pool Water Problems
    Last Post: 09-11-2006, 07:18 PM
