Results 1 to 10 of 33
Thread: No Chlorine at all in pool...
    BigDave's Avatar
    Default Re: No Chlorine at all in pool...
    Watermom, I posted while markcobra's post was still in mod queue.
    markcobra, While the FAS-DPD test can be bleached out, it is far less likely than DPD or strips. Also if you put two scoops of powder in the the 10ml sample and swirl it you will porbably see a flash of pink before it bleaches out a third may turn it pink. No flash, no pink, no chlorine. No chlorine, go after it with bleach adding 6 gallons 6%, let it mix and then test - you should start seeing CC if you're fighting ammonia.
    I think you went a little overboard with the liquid chlorine. 10 gallons of 10% l would have added about 43ppm of chlorine. See what you have in the morning.
    Jun 2012
    Thanks for all the replies keep them coming! I have to go to work but I did quick aquachek test strip and FC is very dark purple. PH is a little. TA and CYA seem good. Will do a test with K2006 when i get home. Using the drops for FC and not getting the sample to turn clear means I got alot of chlorine in there? I added over 100 drops and it wasn't turning at all.
    I guess whatever was going on is gone since I put alot of liquid chlor in? Should I let the chlorine come down a little now over the next few days on its own?
    The 2 gallon bucket test has no FC in it.
    I did test for ammonia before dumping chlorine in and it was 0. How long until this chlorine goes down? Its sunny here today and I left filter on all night.
    Jun 2012
    Default
    Just got home and did a quick test strip again and according to that thing are in line except chlorine is high but alot less dark purple than it was. Pool absolutely looks fantastic.
    My question what do I use to maintain chlorine in the pool? Should I continue with the trichlor pucks in floater? I'd like to stick with liquid chlorine to shock. Not gonna use powder anymore after I use up my last 3 bags.
    I guess I had algae on my walls even though I had been shocking and scrubbing walls I could never get them clean because those walls now look super clean. Ammonia levels were 0 before I chlorinate bombed the pool. Phosphate level is rather high around 400. I just put a liter of pool perfect with phos free in skimmer. Gonna let it run for 48 hours. Pressure is around 24 so I may have to backwash. Gonna post a Taylor reading in a little bit.
    When you post your numbers, be sure that CYA is one of them. Whether or not you can continue to use the trichlor pucks depends on what your CYA level is.
    I wish you hadn't added the Phos Free. I'm going to encourage you not to add any additional stuff to the water unless you run it past us first here on the forum. Most of the time, what pool stores tell you to add is not needed and often makes a mess of your water. I'm pretty certain you didn't need the Phos Free. I've never seen a pool yet that did.
    Jun 2012
    Ok. I have the aquachek strips for Phosphates that where I got the number. So I put my polaris in and it must be kicking up some dust cause the pool is getting cloudy or is it the phosfree?
    Taylor results:
    FC 5
    CC .04
    PH 7.2
    CYA 41
    Mark
    20 yr old 23K gal concrete pool; DE filter; PF:5
    Jun 2012
    Dumb question...I'm gonna go shock with 3lbs of cal-hypo. Should I let the filter run all night?
    I can't get enough of this site LOL... you guys are the best! No more listening to pool store for me.
    Not necessarily. I guess if you are just broadcasting the cal hypo, you don't have to run it at all.
    Jun 2012
    Alright so I guess I can start going in the pool now as long as I'm maintaining proper chemistry? My wife and I have 3 kids ages 4, 3, and 1. I didn't let anybody swim in it yet while I was battling the no FC issue.
    I don't worry about Phosphates and Nitrates?
    Also when I add bleach at dusk do I run the filter all night or just for an hour or 2 or not at all? I set my filter to run 8am-8pm.
  1. Chlorine tabs vs chlorine bleach generic
    By Cahoonh in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-13-2013, 10:28 AM
  2. High Chlorine Level with no Chlorine Added in 6 weeks
    By morechoff in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-27-2006, 08:52 AM
  3. Free Chlorine vs. Total Chlorine adjusting
    By Truckman in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-08-2006, 06:00 PM
  4. alternatives to chlorine/non-chlorine pool maint
    By leewest in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 04-04-2006, 11:53 PM
