Re: Moblaine's pool
PoolDoc
I don't know what that could be. As noted above, the "mineral pack" contains 99.5% of something "inert" but that doesn't mean it can't react with high chlorine. Can you take it out? It's not impossible that it's the source of your CCs. Are you pouring the chlorine in via the skimmer? If so, change to pouring directly into the pool, preferably in front of a return, so it will mix rapidly.
No, I'm pouring the liquid chlorine all around the pool each night, primarily in front of the return jets then I brush to move the water around. Yes, I can take the Mineral Reservoir out and see if things change but then I'm unable to use my tri-chlor tabs. Is this okay for a few days since in lieu of the tabs, I'd be super-chlorinating each evening? Or, am I asking for trouble that way?
16'x36' rectangle 21K gal IG vinyl pool; Trichlor feeder; Hayward DE 4820 DE filter; Pentair Superflo VS pump; 12-14 hourshrs; Taylor K-2006; delivered via truck; summer: solar; winter: mesh; ; PF:4.8
