Mastamoon, you are over-controlling your pool. It's a pool; not a set of numbers. The numbers will NORMALLY vary some over time and trying to FIX this normal variation just wastes money and effort.
Let me suggest a few guidelines for you:
1. There are just 4 'fix-it-now' issues in your pool: low chlorine; pH below 6.8 or above 8.2, growing algae.
2. For EVERYTHING else, do NOT change your routine until you have AT LEAST 2 readings on succeeding days show a SUSTAINED out of norm condition.
3. To reiterate: do NOT adjust and do NOT report here, until you have TWO out of range test, NOT from the same day.
