Summary: I think my pump is too large for my 200lb sand filter. Everything shoots thru the filter when vacuuming. I am currently dealing with the problem by holding knee high pantyhose over the return jet while someone else vacuums. This catches all the small stuff except the de powder. I am currently having problems with my pump "freezing up" and I have to pound the housing with a rock to start it pumping. I assume it is going down and I am looking to purchase and properly sized pump for 2 reason: 1. so that it will be able to filter properly using the 200lb sand filter, 2. to save on the electric bill.
NOte 1: When my husband tried to work on the above pump (that had quit working after our 10yr son turned it on but did not pound on the housing to get it started), he realized that it was wired into an OUTSIDE breaker box that went to the garage. Since I had checked the breaker box INSIDE the house, he checked the outside breaker box and yes the breaker was tripped! So with a little pounding the pump is now working again. For now.
Note 2: I am surprised at the difference between the prices of the Whisper Flow and the Hayward. The Hayward is half the price of the Whisper Flo. If I understand you right, however, you are saying the Whisper Flo is better quality and will last longer? We do have a budget but I dont want to skip quality (aka lasts longer?) for this reason....................And it looks like it would be the same price to replace just the motor on my current pump as to buy the smaller Hayward
